1993 zx wheels and forks on a 1977 kz 650 ?????
  • motojunkey
  • motojunkey's Avatar Topic Author
13 Nov 2011 02:26 - 24 Nov 2011 02:32
#488260
I want to put zx wheels on my ahrma kz 650 racer but would like to keep the ride heigth for cornering.
I can allways use longer rear shocks but I'm having trouble getting longer fork tubes.
I like the 41mm fork tubes but there inches short.
Or should I try and use the stock kz front end and try and modify to accept the zx ft wheel.
I'm currently healing up from touching down hard with a racebike that had low ride heigth.
zx ft wheel to wide for kz forks so it looks like I'll use the zx forks.
Last edit: 24 Nov 2011 02:32 by motojunkey. Reason: update
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: 1993 zx wheels and forks on a 1977 kz 650 ?????
14 Nov 2011 14:32
#488446
www.frankmain.qpg.com/
these folks can build you new tubes however long you want.
  • motojunkey
15 Nov 2011 02:04
#488540
I called them--they said they couldn't make them.
  • 531blackbanshee
  • Vendor
  • Vendor
15 Nov 2011 11:18
#488576
really?
that sucks.
what about extended fork caps.
if not readily available can be custom made..
  • motojunkey
06 Dec 2011 01:40
#491827
I'm gonna put the zx 600 d front end on.
stock lower steering bearing will work.
Top one had to get all balls thinnest one.
will update when i get bearings.
  • motojunkey
07 Dec 2011 02:31
#491988
Don't forget steering stop.
  • wireman
  • wireman's Avatar
07 Dec 2011 02:37
#491990
have you looked at wider triple trees from a cop bike with your stock forks?
kz900/1000 forks are same diameter but roughly 3/4" longer if youre looking for more ground clearance B)
  • DoubleDub
  • DoubleDub's Avatar
07 Dec 2011 10:56
#492017
I'm watching...have a Kz650 build going too (slowly). :)
  • StreetfighterKz
  • StreetfighterKz's Avatar
07 Dec 2011 12:27
#492029
wireman wrote: have you looked at wider triple trees from a cop bike with your stock forks?
If it helps, I'm using a Police front end with a ZX11 front rim and brake system. The Police front end bolts right on in place of the stock front end without the need for a bearing swap.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Fritula
  • Fritula's Avatar
  • holly land garage
11 Dec 2011 03:53 - 11 Dec 2011 03:54
#492621
check this:
Last edit: 11 Dec 2011 03:54 by Fritula. Reason: add
  • Fritula
  • Fritula's Avatar
  • holly land garage
11 Dec 2011 03:59
#492622
can not make a link,so here it this way: http-www.allballsracing.com-index.php-forkconvertion you just have to fill up your bike brand,year etc,and they give you a list of forks that fit your bike. Plus they give you a new bearing size that go with it. Awesome!!!!
  • motojunkey
12 Dec 2011 02:25
#492741
latest update.
