steering bearings
- dan76kz900
steering bearings
20 May 2006 19:55
I need to replace my steering bearings before I put my forks back on my frame. I figured out today when I was about to assemble the front back together that the bearings are not good.
Can anyone give me some bearing numbers I can take to a bearing house for them to look up ? I got numbers off the bearings I had.. but all I found was "30K" and on the bottom bearing "30KW". That was all..
Any help - Thanks !
Any help - Thanks !
- jbw7300
- you can't ride if your fried
Re: steering bearings
20 May 2006 19:59
why don't you try allballsracing.com thats where i got mine
www.allballsracing.com
84 kz 700 a1 sports
- jbw7300
20 May 2006 20:00
sorry double post , i don't know why that link won't work just type it into your browser, also you could try z1 enterprizes
Post edited by: jbw7300, at: 2006/05/20 23:02
84 kz 700 a1 sports
- jbw7300
20 May 2006 20:05
allballs shows 22-1014 for a part # and $36 for the bearings and seals
84 kz 700 a1 sports
- dan76kz900
20 May 2006 20:06
I could order from one of those places.. I wanted to get them locally if I could.. so I can get it together sooner
Also.. I dont think there are any seals for me is there ?
Post edited by: dan76kz900, at: 2006/05/20 23:08
- jbw7300
20 May 2006 20:13
z1 lists them also and they had the measurements 30x48x14 30x52x17 hope that helps
84 kz 700 a1 sports
- jbw7300
20 May 2006 20:26
by the way the part #'s I gave you are for tapered roller bearings witch are a GREAT inprovement from your ball bearings, and your probably right about having no seals for those old bearings, the tapered ones have seals
84 kz 700 a1 sports
- steell
20 May 2006 21:49
Are you sure the tapered bearings have seals? I don't recall seeing any on the ones I have done, but maybe I just don't remember them
- Leather
20 May 2006 23:03
I have to agree about the tapered Allball bearings.. made a world of diffrence in the front end feel. And I think the tapered ones are sealed . least I think mine were discribed that way..I liked the fact it was a drop in and go fix...lol
- jbw7300
21 May 2006 05:53
yep just did mine on my kz700 a couple a weeks ago had two seals one for the bottom an one for the top, when i took mine apart it had tapered bearing in it but no seal on the bottom, don't know if po had replaced them or not but they were shot to hell
84 kz 700 a1 sports
- steell
21 May 2006 10:45
Ok, so you are saying there are separate seals?
When I read " the tapered ones have seals" I took that to mean they were sealed bearings, and I have not seen any sealed tapered bearings.
Guess I just misunderstood (again)
But I still don't remember any seals coming with the tapered bearings I have installed on the 750 twins.
But maybe that's only the 750 twins.
- dan76kz900
21 May 2006 12:57
Sounds like my best bet is to order the kit - that way I'll get the seal if there is one. I'm assuming allballsracing's kit comes with bearings and races right ? How is their shipping ? price, speedy ? Where do they ship from ?
