fork swap
- lambert II
fork swap
04 Nov 2011 00:54
about to get into a long one here i know, and i have searched and came up with this so far, the stem for a vn1500 has the same upper and lower dimensions, now does anybody know of a way to get overall dimensions, short of me finding someone with one and asking to take a tape to their bike and get a rough estimate. Im looking at a complete front end off one for a cpl reasons, main being oil and spring forks over air and oil, but also, detachable risers and 1" bars. Just leaves open more possibilities.
82 kz1100d1 spectre
- mark1122
- Keep twisting it
Re: fork swap
04 Nov 2011 19:15
the normal method of switching front ends is to remove the 2 stems from the 2 dif trees. then u put the stem from your tree into the new doner tree. this way it bolts right up. u may have to machine a sleeve, to fit your stem into the new tree, if its diameter is smaller than the donors.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- TeK9iNe
- What did you do!?!
Re: fork swap
04 Nov 2011 22:52mark1122 wrote: the normal method of switching front ends is to remove the 2 stems from the 2 dif trees. then u put the stem from your tree into the new doner tree. this way it bolts right up. u may have to machine a sleeve, to fit your stem into the new tree, if its diameter is smaller than the donors.
Yep.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kenthewrench
- RIDE IT LIKE YOU RENTED IT!!!!!!!!!!!
Re: fork swap
06 Nov 2011 20:12
Don't mean to hijack thread,but whats a good donor bike model to get a set of 40mm forks from for my recently accuired KZ1000E shaft bike ? Thanks======Ken
- lambert II
Re: fork swap
08 Nov 2011 19:23
hijack isnt a problem, i found a nice cross refernce section on OHIO CAFE RACERS site (
www.ohiocaferacers.com/
) and go to tech tips. if im not mistaken the sems are the same size on hte two bikes i referenced, and *should* be a direct swap
82 kz1100d1 spectre
- kenthewrench
