Information on installing GS1100 swing arm
  • MTH76
  • MTH76's Avatar Topic Author
01 Nov 2011 13:54
#486492
I am in the process of installing a GS1100 swing arm on my 1976 KZ900.
Along with this swing arm I purchesed a 3.5 inch wide rim.
My question is how wide of tire will work with combination and will I need to offset my front sprocket?
Right now I am just starting to round up parts for this winter.
I have heard that it is not that hard of a job.
Right now I have a Kossman double clubfoot 6 inch over swing arm.
6 inch wide rear wheel with a 180 rear tire 3/8 offset in front.
I want something more ride friendly.
Thanks for the help.
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
  • ramtough_63
  • ramtough_63's Avatar
Re: Information on installing GS1100 swing arm
01 Nov 2011 23:43
#486616
i run a 130 about as wide as the wheel will allow with standard drive I'm wanting to go wtih the 180 tire what are your dislikes about it?? I am sure with some inginuity a 140-160 is an easy adaptation but thats a guess on my part.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • MTH76
02 Nov 2011 08:40
#486670
I want to get back to a shorter swing arm, also I am using the stock blinkers.
The problem with this is when you hit a hard bump with shocks the tire hits the backside of the blinker stalk.
Are you running any offset on your front sprocket?
I do get alot of complements on the set up I just want to be able to enjoy riding it more.
It is great stop light to stop light but it doesn't like the turns as much.
Also are you using Suzuki rear shocks,I just recently put on brand new progressive shocks and hate to give them up.
  • donthekawguy
  • donthekawguy's Avatar
04 Nov 2011 03:24
#486944
I have a 140 on mine with a 5.5 inch rim. I switched to a 530 chain and used a front sprocket spacer from z1ent. Not sure of the size I used but everything lined up.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • ramtough_63
04 Nov 2011 20:09
#487030
no the 130 is stock everything i put an integrated tail brake turn on mine so the signal bump not a prob. let me know if you sell your setup might save me some time
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • MTH76
10 Nov 2011 15:41
#487907
I will be removing the complete rear end this winter and would be interested in selling it.
That would include the swing arm,wheel and tire,caliper and rotor,stainless steel brake line.
15 tooth offset front sprocket,sprocket support plate,35 tooth rear sprocket and chain.
18 by 6 inch wheel with 180 tire.
Everything would bolt right up.
I will take plenty of pics before I remove.
  • kzrider77
  • kzrider77's Avatar
17 Feb 2012 03:20
#504539
did you ever sell the GS1100 sey up?
  • MTH76
21 Feb 2012 09:00
#505447
PM sent.
