Interchangeable wheels
  • Mine20
  • Mine20's Avatar Topic Author
  • Metric Maniac
30 Oct 2011 23:50
#486175
I'm ready to kick off my build, did a littler tinkering today. Sorting parts, checking carbs, going through electrical. Reading up on the differences between the bikes I have. Now the first thing I noticed was the wheel sizes. The front on the kz is a 100/90/19 which is the same on the sr. However the rears are different, the kz is a 100/90/18 and the sr is a 130/90/16. I like the wider tire of the 130 and want to go with that wheel on the kz. Is this doable? Is it a straight swap?
Also, what is the differences in the frame between the kz and sr? The sr seems to me much lower than the kz.
A few other things that will be swapped
1. sr drilled front rotors are going on the kz
2. clubman bars going from sr to kz
3. 4-1 exhaust is going on the kz
Thanks for the help.
M20
2007 Honda Shadow Custom
1978 Kawasaki kz650c2 cafe project
1979 Kawasaki 650sr possible bobber project
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
Re: Interchangeable wheels
31 Oct 2011 02:42
#486202
I swapped the 18" Enkei for a 16" Enkei on my 750. I even did it for the same reason as you. It was a straight swap. I just had to put the rotor on the 16", and put it on. I even used the sprocket carrier from the 18" with no issues.
As far as the frame difference, the models are usually identical, or very similar from the neck to the beginning of the "sub frame". Take a close look at the front of the "sub frames" and I'll bet you notice the difference.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • Mine20
  • Metric Maniac
31 Oct 2011 22:58
#486398
It's a bit cramped in the garage right now. I have an extra fridge in there right now, and my chicks car. So all that and 3 bikes makes it shitty. I'm anxious to get this kicked off.
