CALLING ON ANY INFOFROM ANY STRETCHED SHAFTIES!!!!
- lambert II
30 Oct 2011 22:37
ok guys, decided what route i wanna go on my 82 spectre 1100, im gonna stretch it, and hardtail the frame. No i dont mean just replace the shocks with struts, i mean i true hrdtail that the final drive sits in that just happens to have a shaft drive, just curious how long i can safely go.now the way i plan on doing this is the way a shop over in europe has been doing it for yrs... heres what i got from them
"Hi Brian
The proper way would be to cut off the front & back ends of the shaft that you want to use, leaving about 2" of stub on each end.
Get a bit of good steel (chrome moly works) of larger dia - say 1" - of the right length, machine the ends to accept the stubs with a press fit, press together and TIG weld.
Its good if you can arrange it so the weld goes round a larger diameter part of the stubs than the main shaft diameter - where it flares out.
Hope this helps
Briz"
now i was thinking about a 10 to 12 inch stretch, but has anybody else ever went this far?
"Hi Brian
Hope this helps
Briz"
82 kz1100d1 spectre
- Chaotic Reason
Re: CALLING ON ANY INFOFROM ANY STRETCHED SHAFTIES!!!!
31 Oct 2011 01:12
My brother has had it done on cars to splice in a new drive axle, but I haven't seen it done on a bike. I don't imagine it's that different. I know a good machine show will then put it on a lathe to make sure it's balanced properly, but other than that, I wouldn't know any more.
Being that I have a shaft drive myself, I'm looking forward to reading what others have to say.
Michael
1980 KZ1000 shaft drive
- Chaotic Reason
31 Oct 2011 01:15
Oh, and did you never get the micrometer to check the dimensions you posted about in your other thread?
Michael
- lambert II
31 Oct 2011 23:08
Not really needing a micrometer, just a chance to pull the axle and get the length and diameter.
82 kz1100d1 spectre
- 82SPECTRE
01 Nov 2011 02:00
My only advice would be to watch your driveshaft angle very closely when your doing the hardtail conversion. Im having problems with mine now because it is just a hair unlevel and is clunking like crazy... Not good
1982 KZ 750 N1 SPECTRE
- lambert II
03 Nov 2011 01:07
hey 82, did you stretch it at all, and can you get me a cpl pics of the setup you have running?
82 kz1100d1 spectre
- Motor Head
03 Nov 2011 10:03
The operating angle of drive-line U-Joints will let the shaft work at up to 3 degrees. That's the difference between the output of the Power from Engine/ Transmission, and the center of the Shaft tube. then again on the Output of the Shaft tube to the Differential/ final drive. Balance after shorting, as well as straight and true, with good U-Joints/ not binding, is needed.
So with the hard tail, shaft just UN-level: Is the operating angle of either end, U-joint, over three degrees?
have a look at any rear wheel drive Car or Truck. Look at a 4x4 Jeep, Stock of course not lifted, and see how the drive-line angles are.
- Red Good
11 Nov 2011 14:31
You have picked one of the best to ask , Briz is one of the most knowledgeable builders out there and because he has done most everything that can be done to a motorcycle it's based on practical experience .
Any help we can offer just email Kate . Red
- 82SPECTRE
23 Nov 2011 19:45
No it is not stretched at all. I just switched the stock springs with rigid struts and they are about 9". Im not sure if the shaft has exceeded 3 degrees but I bet that is the problem. Although i have seen other builds online that seem to also exceed the 3 degree rule and they have no problem...
- 82SPECTRE
23 Nov 2011 19:47lambert II wrote: hey 82, did you stretch it at all, and can you get me a cpl pics of the setup you have running?
Ill post pics of it as soon as i can get them uploaded
