KZ-750-E brakes
- DanAir
KZ-750-E brakes
19 May 2006 13:09
I'm dusting off the ole bike to put it back on the road.
Found the brakes were empty of fluid. Someone said flush them out with denatured alcohol and then refill with DOT -3 & bleed. Does this make sence? THANKS !
- steell
Re: KZ-750-E brakes
19 May 2006 16:49
I accidentally flushed the front brakes with laquer thinner one time (got distracted and grabbed the wrong can). As soon as I realized what I did I flushed them with DOT 3, and never had a problem afterwards.
I don't believe I'll do it again though
I have never tried flushing the system with alcohol though, as long as you immediately flush with brake fluid it probably won't hurt.
- wireman
Re: KZ-750-E brakes
19 May 2006 20:47
alcohal is the only thing you should use to clean it out,will not affect rubber seals like petroleum based products.then refill with brake fluid.
- kzbikeman
Re: KZ-750-E brakes
20 May 2006 13:10
alcohol will absorb water better than about anything. Water is waht you need to purge from your system for a variety of reasons. It has a low boiling point which can lead to air trapped in your system and it can corrode everything turning it into a rusty, muddy mess.
I am rebuilding my front brakes with all new components. The recommendation from the classic racers is to use DOT 4 fluid with its higher boiling point than DOT 3. I wanted to use DOT 5 because it is not caustic on finishes. Anyone have any ideas on that?
- Snakebyte
Re: KZ-750-E brakes
22 May 2006 09:47
Yes you have to replace your seals with new ones. You can mix dot 3 with dot 4, but not dot 4 with dot 3. If you want too convert too dot 5 (no need too, unless yu just want bragging rights) Then you need to replace every seal and clean metal with brake cleaner or d_alcohol.
Keep in mind the characteristics of brake fluid:
absorbs moisture
high boiling point
low freezing point
Good lubricater
There is a fith one but I have seem to have lost my brain at the moment. :pinch:
absorbs moisture
high boiling point
low freezing point
Good lubricater
- DanAir
Re: KZ-750-E brakes
18 Jun 2006 07:13
I just wanted to let you guys know that flushing the brakes with denatured alcohal worked quite well. Used about a pint of alcohol; and same amount of DOT 3 to flush out alcohol and bleed two masters and three slaves. Thanks!...Now working on carbs, new post there.
1981 KZ750E
1981 KZ750E
