stuck rear wheel
- abrambila
stuck rear wheel
25 Oct 2011 01:10
1978 KZ650 D1
Hey guys, my rear wheel is not spinning as freely as it should. The caliper is not seized up and the pads are not rubbing on the rotor. I pulled the axle out and lubed it as well as repacked the bearings. When it was put back together it spun freely until it was torqued. When torqued, it does not move as freely as it should.
Any ideas?
Thanks.
Any ideas?
Thanks.
1978 KZ650 D1
- MFolks
Re: stuck rear wheel
25 Oct 2011 01:24
Do you have the correct spacers and are they in the correct locations?
Last edit: 15 Feb 2013 12:01 by martin_csr.
