Fork,tree and wheel alignment
  • glory roader
  • glory roader's Avatar Topic Author
24 Oct 2011 22:29
#485146
Has anyone had problems lining up their forks with used trees? I have two sets of forks and this is the second set of trees I have had issues with. Seems when I tighten everything up the forks go out of alignment. This is the second set of trees doing the same thing.
I just want to know is it more plausible that the trees r deformed or the forks?
  • z1kzonly
  • z1kzonly's Avatar
Re: Fork,tree and wheel alignment
24 Oct 2011 23:28
#485169
Something has been tweeked! Is this your original frame? And not been hit or dropped?
It don't take much to bend a frame. Or if you buy triple tree's off of ebay or whatever.
The stem could be bent. Big sledge hammer and a block of wood! I have had frames chained to a tree, then twisted out of distortion! If the owner had seen them they would have screemed!
But , they come back to shape.
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
25 Oct 2011 00:10
#485177
z1kzonly wrote: I have had frames chained to a tree, then twisted out of distortion!
Ok....I don't feel so bad about using a crowbar on my '66 A1 frame to fix a bent rear peg mount now... LOL! :)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • donthekawguy
  • donthekawguy's Avatar
25 Oct 2011 03:04
#485212
I had the same problem on my bike. I loosened everything up on the front end except to top bolt holding the forks on the tripples. Sat on the bike put the front wheel up against a post and pushed the bars until they were straight. I had the kid loosen the tight bolts then tighten everything up while I held the bars straight. 3 years of riding around with crooked bars and a ton of money replacing every part on the front end. The fix didnt cost a dime. :angry:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • martin_csr
  • martin_csr's Avatar
Re: -
25 Oct 2011 11:41 - 18 Feb 2013 17:53
#485265
Last edit: 18 Feb 2013 17:53 by martin_csr.
  • clutch
  • clutch's Avatar
12 Nov 2011 06:12
#488144
martin_csr wrote: After installing everything on the bike, you can place a small piece of glass on the tubes to check the alignment.
Interesting. How would this test work? I'm finishing up the front end of my '66 A1 tomorrow, and would like to know how to tell for sure they are aligned properly :)
Wish List:
  • martin_csr
Re: -
12 Nov 2011 11:59 - 18 Feb 2013 17:59
#488159
Last edit: 18 Feb 2013 17:59 by martin_csr.
