Z1R tank emblem screws seized and snapped off...
  • 300kph
  • 300kph's Avatar Topic Author
23 Oct 2011 05:22 - 23 Oct 2011 05:38
#484841
One side of my recently painted Z1R tank (done to perfect original starlight blue code) has both emblem screws seized and heads snapped off flush. The other side is A-OK.
It was a tank that endured a year or two outdoors and it was like that when I bought it.
The painter never made any attempt to remove them and I would like to unseat them as I have new emblems and screws.
Any ideas? I fear using deep penetrating oil may damage the finish.
Can something that small be drilled and tapped?
In a perfect world I would somehow be able to remove them and retain the threaded holes.
Anyone?
Wayne
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
Last edit: 23 Oct 2011 05:38 by 300kph.
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
Re: Z1R tank emblem screws seized and snapped off...
23 Oct 2011 07:50
#484848
They are very small indeed....probably to small to use a what we call "an easy out ".
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
  • trianglelaguna
  • trianglelaguna's Avatar
23 Oct 2011 10:00
#484860
boy they make some tiny drill bits and easy outs...i bet a drop of oil...a tiny center punch ,one square tap....and some easy drilling with a fine metal drill bit...the screw will rotate on the drill bit.....and reverse the drill...they come out...or...they do make tiny easy outs and if lightly turned by hand in the tiny drill bit hole...will walk that emblem screw right back out....worked for me...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • martin_csr
  • martin_csr's Avatar
Re: -
23 Oct 2011 10:25 - 18 Feb 2013 17:50
#484864
Last edit: 18 Feb 2013 17:50 by martin_csr.
  • ramtough_63
  • ramtough_63's Avatar
23 Oct 2011 11:48
#484878
if you can get on em with some small vice grips (the small ones they sell in the barrels at lowes)clamp on twist out. done several that way. Almost every set has been messed up when I got em have had to use a flat screw driver and a hammer to unscrew also. NO OIL ON NEW PAINT no silicone no wax no soap. havent had to drill any out drill bits with boken screws spinning in a drill on my new paint makes me nervous just typing it
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • gane
  • gane's Avatar
23 Oct 2011 17:18
#484921
A couple tips if you elect to drill...An "automtic" (spring loaded) center punch allows for indenting (to be drilled ) bit, & allows for correcting to exact center w/ repeated application. when drilling, start small (say 1/2 dia of piece). use l/h drill bits & either 'shorten" drill bit, or "sleeve" it so that if you should happen to drill thru you can't penetrate tank. If l/h bit walks broken bit out, you win ...If not increase bit dia, til you can break out remainder. (said punch is great for this,working from outside dia around circumference.) Bear in mind, the "Ears" your' working with are only a couple threads deep, be gentle, If worried about slipping, tape some kind of "protecter" around working area. Luck G
[img][/img] 1977 KZ1000A1
