lowering a bike
- longshorecoma
lowering a bike
19 May 2006 07:23
I have a good idea asto lower the back. but the front is the question. a has anybody ever seen a lowaed ltd 1000 with out an extended swing arm?
- Pterosaur
Re: lowering a bike
19 May 2006 07:39
longshorecoma wrote:
Sure. Quickest, safest route to a lowered tail I've seen is a set of HD Sportster "Hugger 883" (chick bike) shocks.
Never seen a set of struts - or what they do - that I cared for...
- wireman
Re: lowering a bike
19 May 2006 07:46
slide forks up in triple trees make sure you lower rear of bike first though.
- waterman
Re: lowering a bike
19 May 2006 08:08
Hey wireman. You spooked me a bit. I had a pair of sporties on and my forks a inch up in the trees. Now I've put on Zrex shocks (boosts me back up about an inch), can I still leave the forks where they are and be safe??
- donthekawguy
Re: lowering a bike
19 May 2006 08:31
I lowered mine by getting a set of lowering tubes from schnitzrcing.com. You have to take the forks apart to get them in but I like it better than sliding the forks up in the clamps. They only cost about $15 and come in a few different sizes. Just be carefull when you first ride it due to ground clearance.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- wireman
Re: lowering a bike
19 May 2006 08:48
waterman wrote:
lowering the frontend and raising the rear does strange things to high speed handling,some people will disagree with that but in my personal experiance it can get real scary with a tank slapper at 100mph,been there done it and somehow walked away but my shorts were never the same afterwards!:S :blink: :whistle: :woohoo:Hey wireman. You spooked me a bit. I had a pair of sporties on and my forks a inch up in the trees. Now I've put on Zrex shocks (boosts me back up about an inch), can I still leave the forks where they are and be safe??
- dutchz
Re: lowering a bike
19 May 2006 08:56
Hey waterman. I rode around with dropped forks and zrx shocks for a while without any problems. The bike did turn in a lot easier. I would still be running the ZRX shocks but they looked to damn modern on my bike, trying to find something that looks more vintage. Going back to my 30 yr old stockers was a "shocker" though hehe.
1974 Kawasaki Z1
Stock front hub and rear axle.
- longshorecoma
Re: lowering a bike
19 May 2006 10:04
Thanks guys I'll shech out the HD shocks and see how it turns out. Hey do you post a picture in the gallery. Id like to see what you guys think of my horse.
- longshorecoma
- Nevco48
Re: lowering a bike
19 May 2006 12:54
Go to the Gallery, then click on the User Panel, should walk you right through it. Make sure your pic is sized small enough.
- Mark Wing
Re: lowering a bike
19 May 2006 19:10
dutchz wrote:
Yes it will turn easier at the expense of high speed stability.
When I'd go to the drags I'd slide the tubes up and put some struts on the back.
Mark
Post edited by: Mark Wing, at: 2006/05/19 22:24
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- agawam
Re: lowering a bike
19 May 2006 21:31
I lowered the front of my 78 650SR by installing forks from a 76 kawi KH500
