raking the frame
  • jordan
  • jordan's Avatar Topic Author
raking the frame
20 Oct 2011 23:47
#484407
I have been working on a buddy of mine's kz1000. its 1200cc's, welded crank, forged pistons, and a well built head on nitrous. The drag header leaves very little room from the front wheel. Hes looking to have it raked. Anybody know what a typical dragbike rake degree is? What kind of shop should do it? I live in SD so speedshops and such are few and far between. Is this something an average machine/welding shop could do? Im also considering doing this on my gs1100e. Stock frontends usually used after raking?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • DoubleDub
  • DoubleDub's Avatar
Re: raking the frame
20 Oct 2011 23:54
#484410
Not sure I'd let just any shop take a whack at it. Some shops might be able to do it, but someone with experience with a frame jig is where I'd head.
  • z1kzonly
  • z1kzonly's Avatar
20 Oct 2011 23:58
#484411
Hey Jordan, You got to have a car, frame guy around, somewhere!
They will no what to do. Cut the neck off and put some pieces into it!
Attachment 1rake.JPG not found
  • jordan
21 Oct 2011 00:00
#484412
there is a few dirt track race chassis builders around but the one close by is not interested. and the local shop that does truck frame repairs said that its too much of a liability. There is a chopper builder in sioux falls, sd that i contacted and am awaiting a reply
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
21 Oct 2011 06:33
#484437
There is a lot more to it than just cut the neck out and add some pieces. I'll elaborate more this evening
Day job request my presences :(
  • jordan
21 Oct 2011 11:48
#484464
Same reply from chopper builder, too much of a liability :(
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • wireman
  • wireman's Avatar
21 Oct 2011 21:49
#484561
jordan wrote: I have been working on a buddy of mine's kz1000. its 1200cc's, welded crank, forged pistons, and a well built head on nitrous. The drag header leaves very little room from the front wheel. Hes looking to have it raked. Anybody know what a typical dragbike rake degree is? What kind of shop should do it? I live in SD so speedshops and such are few and far between. Is this something an average machine/welding shop could do? Im also considering doing this on my gs1100e. Stock frontends usually used after raking?
stock gs1100 e's tend to corner/handle like an occ chopper in stock form with their weird ass steering geometry! :sick: :woohoo:
3 degrees is about id suggest for a street bike myself,if you can wait till i finish my project in kearney ill come up there to brookings and help you if the frame is already stripped down B)
The following user(s) said Thank You: fat z
  • jordan
21 Oct 2011 23:56
#484586
well i can have the frame stripped in about an hour haha. The GS needs to be raked just enough to keep the header off of the pipe. A full dragbike rake is kinda what im looking for. It will be an occasional strip bike, but will also be on the street but dont plan on doing any fast cornering maneuvers. It will have a 6-8" over arm on it by the end of winter.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • wireman
  • wireman's Avatar
22 Oct 2011 13:15
#484671
once you get much over 3 degrees of extra rake on a kz frame for a streetbike it will start to handle even worse than that gs1100. :woohoo:
if you plan on doing anything radical with an 82 or older gs1100e i stronger suggest getting the crank worked on. B)
id rather take my chances with a stock unwelded kz1000 crank with a low boost turbo than to hotrod around town on a stock 82 1100e with an untouched crank,yeah ive had my share of handling/bad crank issues with the 1100 suzuki! :sick: :woohoo:
as far as 6" on a streetbike swingarm once you get much past 3-4" over you start moving weight away from the back tire then youre stuck with a 170-180 tire to make up for lost traction,but then youre adding extra weight and chain issues,shock issues................
my 80ltd/z1 1327 mutt ran pretty consistant 6.17-6.18 times in the 1/8 with an unraked frame and a 3" over arm and a small tire without a bar,1st 100' usually involved lots of praying(and my pacemaker bouncing off its rev limiter :sick: )but i had plenty of motor to make it up on the top side! :laugh:
22 Oct 2011 16:14
#484706
jordan wrote: well i can have the frame stripped in about an hour haha. The GS needs to be raked just enough to keep the header off of the pipe. A full dragbike rake is kinda what im looking for. It will be an occasional strip bike, but will also be on the street but dont plan on doing any fast cornering maneuvers. It will have a 6-8" over arm on it by the end of winter.
Why stop there?
Attachment long_2011-10-22.jpg not found
  • kawman66
  • kawman66's Avatar
23 Oct 2011 00:57
#484823
once you rake it that far and lenthen it that far a simple manuver such as pulling in traffic from a side street is a chore. i rode the bike in my user pic on the street and never again. you will use a full lane on the highway going around slight bends in the highway.The bike im building now has a 4 degee rake and a 3 over arm.And its just slighty slugish in the handleing compared to a stocker.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
  • jordan
23 Oct 2011 13:34
#484892
Well how many degrees of rake are on the first bike, the one in ur picture
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
