Options for Lowering my Bike
- PaulyWally
- Total Bike Newbie
16 Oct 2011 10:44
I want to lower my bike. I'm only 5'6" and I'm on my tip-toes at a stop.
I'm going to be getting a lower profile seat, and that should take 1-2 inches off. I'd like to try and take another inch off the chassis. I've been investigating quite a bit, and aside from chopping, here is what I've found my options to be:
FRONT:
Shorter forks/fork tubes
Remove Stock Spacer(s)
Install Spacers
Smaller wheel/tire
REAR:
Shorter Shocks
Lowering Blocks
Smaller wheel/tire
So... Did I miss anything? What is generally recommended? Any other info/thoughts I need to consider?
Thanks!
FRONT:
Install Spacers
Smaller wheel/tire
REAR:
Shorter Shocks
Lowering Blocks
Smaller wheel/tire
Thanks!
1976 KZ750 Twin
Re: Options for Lowering my Bike
16 Oct 2011 11:18
Riding boots with tall heels, such as cowboy boots, are often helpful.
- DivideOverflow
16 Oct 2011 11:24 - 16 Oct 2011 11:30
In the rear, a lot of people just use lowering links, which adjusts the attachment point of the shocks to a higher point on the bike, that way you don't have to change the shocks or anything else expensive. You just need to ensure that nothing rubs.
On the front, you can just lower the clamp on the forks. There are instructions in the service manuals, but basically it involves loosening the fork clamps, and sliding the clamps down a little. This generally takes 2 people to get it right. You should sit on the bike to measure, make the adjustment, and check again. Also, if you drop the front too much, it will negatively impact handling (more likely to wobble). I guess that is what you were talking about with the spacer...
You should be able to get the adjustment you want without spending a lot of money.
1980 KZ750E1
North Carolina Crew
North Carolina Crew
Last edit: 16 Oct 2011 11:30 by DivideOverflow.
Last edit: 15 Feb 2013 11:40 by martin_csr.
- ramtough_63
16 Oct 2011 16:42
I'm 5'4" slid the forks up used a shorter rear shock. back in the day they made lowering blocks the moved the angle of the shock back. I cant find anyone who makes them now. (brother made a set for my goldwing)I have however seen a few sets go on ebay for crazy money I am gonna order the lowering blocks for the forks from schnitz racing when I disassemble it this winter. because im still on my tip toes unless I wear my old school harley boots lol
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
16 Oct 2011 17:14
Don't be surprised to discover that the lowering blocks result in a very stiff strut-like rear suspension.
