KZ750 Tire sizes
  • DivideOverflow
  • DivideOverflow's Avatar Topic Author
KZ750 Tire sizes
15 Oct 2011 18:57
#483377
This may or may not have been beat to death, but I'm wondering what tire sizes you guys have had good experience with.
The original size for my bike was
3.25 x 19 front
4.00 x 18 rear
The PO put 110/90 x 19 on the front, and 120/90 x 18 on the rear. The front tire he had to adjust the front fender for it to fit (it rubbed a tad prior to him fiddling with it).
Any concerns with those tire sizes? From the charts I've seen, it looks like the front should be 100/90 or 110/80, and the rear is probably fine. Any handling characteristic differences that you guys have noticed between sizes? I've only ever had manufacturer recommended sizes on my bikes.
1980 KZ750E1
North Carolina Crew
Re: KZ750 Tire sizes
15 Oct 2011 19:06 - 15 Oct 2011 19:07
#483378
I'd put a 100/90 19 on the front. 120/90 18 on the rear is fine. 110 is too narrow and 130 does not give any advantage because the narrow rim deforms the tire's cross section so there's no more contact patch than with the 120 (I used 130s for years on my KZ650 and switched to 120). I used Michelins and Dunlops before but now run V-rated Pirelli Sport Demons on mine and I like them a bunch! Ed
Last edit: 15 Oct 2011 19:07 by 650ed.
  • DivideOverflow
15 Oct 2011 19:15 - 15 Oct 2011 19:18
#483380
650ed wrote: I'd put a 100/90 19 on the front. 120/90 18 on the rear is fine. 110 is too narrow and 130 does not give any advantage because the narrow rim deforms the tire's cross section so there's no more contact patch than with the 120 (I used 130s for years on my KZ650 and switched to 120). I used Michelins and Dunlops before but now run V-rated Pirelli Sport Demons on mine and I like them a bunch! Ed
On the front, is there a particular handling issue you think a 110/90 would cause? It seems to handle fine and have quick handling. Granted, I've only had her up to 60mph so far. A 100 would make the tire narrower, correct? Wouldn't that just make it more twitchy?
1980 KZ750E1
North Carolina Crew
Last edit: 15 Oct 2011 19:18 by DivideOverflow.
  • gengomerpyle
  • gengomerpyle's Avatar
15 Oct 2011 19:16
#483381
i run a 140 on the back and a 100 on the front on stock rims
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
15 Oct 2011 19:29
#483384
gengomerpyle wrote: i run a 140 on the back and a 100 on the front on stock rims
I won't try to convince you otherwise if you're doing it, but 140 is too wide to run on a 2.15 x 18 rim without seriously squeezing in the bead and deforming the tread cross section. Maybe check your wheel to see what size is cast into it, it's possible that it is a little wider than the older KZ650/750 rims. Ed
15 Oct 2011 19:32 - 15 Oct 2011 19:32
#483385
100 will make the handling better. Assuming the rest of the bike is working properly it will not be twitchy. I have run my bike up to an indicated 120 mph many times and it is as steady as sitting at a desk (but there's a lot more wind :laugh: ). Ed
Last edit: 15 Oct 2011 19:32 by 650ed.
15 Oct 2011 19:34
#483386
Take a look at the fitment guide:
www.dunlopmotorcycle.com/fitmentguide.asp
  • gengomerpyle
15 Oct 2011 19:38
#483389
it could be a little wider im not sure, the tire was on the bike when i bought it last year.
1982 GPZ750R1 ELR
1971 Honda CB750K
  • bountyhunter
  • bountyhunter's Avatar
16 Oct 2011 15:12
#483537
Yeah, on mine the thing dragged the front fender when I got up to 50 mph.
I run 110-90-18 on the back, 100-90-19 on the front. The rear looks a shade small so you can go up to 120-90-18.
  • bountyhunter
16 Oct 2011 15:14
#483538
The idea is to get the tire width that most closely matches the width the rim was designed for. That gives you the most optimal tread profile.
  • DivideOverflow
16 Oct 2011 16:02
#483541
Did you drag the front fender trying a 110/90? Or a 100/90?
1980 KZ750E1
North Carolina Crew
16 Oct 2011 16:10
#483542
The 100/90 19 does not interfere with the fender at any speed. Ed
