Quick question about brakes!
  • badrhino
  • badrhino's Avatar Topic Author
15 Oct 2011 17:09
#483361
Should you put thread locker on the disc brake bolts when remounting?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • THEHUN
  • THEHUN's Avatar
Re: Quick question about brakes!
15 Oct 2011 17:24
#483364
it is always a good idea to use thread lock specially on bolts holding moving parts or subjected to extreme vibration
  • MFolks
  • MFolks's Avatar
15 Oct 2011 17:44
#483367
I'd say use the Blue Loctite # 242 as it's removable with tools, the Red Loctites need about 300 F to loosen their grip, far to hot for brake pieces.
15 Oct 2011 19:19
#483382
Which bolts? The bolts that hold the rotors on should have locking washers with tabs that bend against the bolt heads. I cannot speak to your model, but the KZ650 service manual does not call for locking agent for the mounting bolts or holder shafts. It does give specific torque values for each type of bolt, so whether you decide to add locking agent or not be sure to torque correctly. Ed
  • badrhino
15 Oct 2011 22:24 - 15 Oct 2011 22:25
#483420
I am restoring this bike so I don't know what all was wrong with it before.
Mine does not have locking tabs....either because it never did or someone took them off.
Also, while I have the calipers off I decided to take them apart. On one caliper the rubber shield/seals for the sliders are in pretty bad shape. Should I just rebuild the brakes completely (rubber shields/piston seals) since they are torn down? One brake looked pretty cruddy so it might have been leaking around the piston.
Where is a good place to get these parts?
Franken Z!
Last edit: 15 Oct 2011 22:25 by badrhino.
15 Oct 2011 22:42 - 15 Oct 2011 22:42
#483424
Below is a drawing that shows the lock washer w/tabs. I don't know if your exact model uses them, but I know that most KZ models do. I would rebuild the calipers since you already have them apart. Z1E should have the kits and the lockwashers. If they don't have the kits, try
www.cyclebrakes.com/
Attachment LockWasher.jpg not found
Last edit: 15 Oct 2011 22:42 by 650ed.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
15 Oct 2011 22:59
#483428
As previously mentioned, all bolts require a very specific torque, and many lock-tite.
If you are not using a torque wrench, you should buy some really good gear.
The proper torques range from lightly tightened to very tight, and cannot be simply guessed.
If you are using a proper torque wrench, then disregard this warning... :lol:
Peace.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • badrhino
15 Oct 2011 23:09
#483430
Thanks, and yes I am using a torque wrench. :P
Franken Z!
  • martin_csr
  • martin_csr's Avatar
Re: -
16 Oct 2011 09:19 - 18 Feb 2013 17:48
#483483
Last edit: 18 Feb 2013 17:48 by martin_csr.
  • badrhino
16 Oct 2011 12:45
#483523
I have the pdf manual for the J model bike but I don't have one for the 1980 KZ1000, are the brake rotor bolts torque specs. about the same? The ones for the J model say torque to 16.5 ft. lbs.
The only reason I have the J model manual is because my bike has the J motor in it.
Franken Z!
16 Oct 2011 16:16
#483545
badrhino wrote: I have the pdf manual for the J model bike but I don't have one for the 1980 KZ1000, are the brake rotor bolts torque specs. about the same? The ones for the J model say torque to 16.5 ft. lbs.
Interesting and a very good question to ask because the KZ650 disk mounting bolts call for 25-33 ft lbs. Hopefully someone has a manual for your exact model. Ed
