I need a Chain Guard
- Kapahulu
12 Oct 2011 06:23
My KZ900 has no mounting brackets for a chain guard, either they were broken or cut off by a previous owner. Annual safety inspections require a chain guard.
Anyone have an easy solution?
I am thinking about buying a KZ1000 swingarm and chain guard (easier to find compared with KZ900). Then I'd just need to put a tab on the bottom of the swingarm to hold the brake torque rod.
What do you think?
What do you think?
2strokeworld.com
2strokeworld.com
- Motor Head
Re: I need a Chain Guard
12 Oct 2011 10:10 - 12 Oct 2011 10:11
No eBay APP ID and/or Cert ID defined in Kunena configurationNot sure if you have an LTD or not. Here is the replacement from Z1 for the A4 model.
www.z1enterprises.com/Chain-Guard--Kawas...0-KZ900-Z1-3218.aspx
If LTD, cgi.ebay.com/ebaymotors/Kawasaki-76-KZ90...&hash=item564682a800
Welding Tabs back on for either would be pretty easy.
Last edit: 12 Oct 2011 10:11 by Motor Head.
- hal0tw0
12 Oct 2011 13:58
Do you have the chainguard itself? For mounting, maybe you could bend up some metal or use some plumbers pipe hanging strap and just rig it up.
www.lowes.com/pd_302125-34146-AV302125_0...%2Bhanger&facetInfo=
www.lowes.com/pd_301353-34146-AV301353_0...6page%3D2&facetInfo=
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- hal0tw0
12 Oct 2011 13:59
Oh and I have a chaingaurd off my Kz900 Id sell you cheap if you need it
- Kapahulu
13 Oct 2011 01:08Yeah I've been thinking about buying some "L" brackets, drilling holes in the swingarm and screwing them on. Or getting someone to weld them on. I have a chain guard off a KZ1000, not sure if it's the same as a KZ900 chain guard or if it matters.hal0tw0 wrote: Do you have the chainguard itself? For mounting, maybe you could bend up some metal or use some plumbers pipe hanging strap and just rig it up.
2strokeworld.com
2strokeworld.com
