Brake pedal return spring
- clutch
- I wish I had a tad more patience to do it better!
12 Oct 2011 01:57
I'm not sure when or where I lost my brake pedal return spring for my kz750 e3, but I have an assortment of springs and one may work. Does anyone have one handy they can measure and take a pic of for me? If you have to remove it from your bike, it will probably be more work than it's worth. I just want to try to narrow down the possibilities out of the spring assortment I have.
Thanks,
Clutch
Thanks,
Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- clutch
Re: Brake pedal return spring
12 Oct 2011 15:02
So I ended up finding a good candidate in the bunch...it's about 2.5 inches long (from loop to loop. I did have to cut a piece of one of the loops off with some bolt cutters so I could hook it on the pedal lever, and then stretched it to fit over the bar on the foot peg mount. I will post a pic or two sometime soon in case anyone else needs to do the same
Wish List:
Wish List:
- clutch
14 Oct 2011 01:48
Here is the pic I promised. I couldn't get a good one of the spring installed, but it works just fine in case you need an easy fix.
Wish List:
Wish List:
