Brake Reassembly
- letthegoodtimesroll
Brake Reassembly
18 May 2006 15:12
When putting the brake calipers on the mounts, what type, if any, grease should you use?
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- OKC_Kent
Re: Brake Reassembly
18 May 2006 20:38
If I recall , one manual I have said to use a hi temp grease, and not much of it. I think there is a special brake grease available at the auto parts stores.
Cashion, OK
78 KZ650 B2 85,000+ miles
19 May 2006 04:55
That's what I used. I had some hi temp disc brake wheel bearing grease so I just rubbed some on the bolts and put them through before I actually assembled the entire thing. Thanks for your response!
