rear brake pad change
- big al
10 Oct 2011 21:21
I have a 1976 kz900ltd. the question i have is- do i have to remove the rear wheel to remove the pads?
- Motor Head
Re: rear brake pad change
10 Oct 2011 21:24
Disc brakes No, Drum Brakes Yes.
- big al
10 Oct 2011 21:29
Thats what i thought, i have disc on the back, oh well i got all winter.
- Motor Head
10 Oct 2011 21:40
The rear brake caliper will have 2 bolts, they are the "Slides" which the Caliper Floats on, this is also the removal bolts. Main Caliper Bracket stays in place.
- wireman
11 Oct 2011 01:13
your rear caliper on that bike should take same brake pads as your front caliper
