Need Help with Center Kickstand
  • Tulsa74136
  • Tulsa74136's Avatar Topic Author
09 Oct 2011 22:09
#482214
1980 LTD 1000, left foot of center kickstand is rubbing on the chain. Rear wheel and chain are installed correctly, chain still has about 50% life left. Is there a "stop" built into the center kickstand that should prevent this from happening ?? Looks like a pain to remove the center kickstand, then I'm screwed when it's time to R&R the rear wheel, chain....etc. Would be embarrassed to post photos of my temp fix.........but it works...........great conversation starter in the parking lot.
1980 KZ1000 - B4 LTD (12/79 Mfd Date)
PODs, Kerker Header, Mikuni 29mm Smoothbores
Vetter Windjammer Fairing & Trunk
1981 KZ1000 - M1 CSR (03/81 Mfd Date)
All Stock except for PODs
1981 Yamaha XJ550H Maxim
All Stock
1977 KZ400 - D4 (2012/13 Winter Project) SOLD
  • Motor Head
  • Motor Head's Avatar
Re: Need Help with Center Kickstand
09 Oct 2011 22:12
#482216
Stock exhaust or a aftermarket set of pipes? Pic?
  • Tulsa74136
09 Oct 2011 22:19
#482219
Aftermarket 4 into 1 header.....it doesn't interfere with the kickstand.
All Stock
  • Motor Head
09 Oct 2011 22:22
#482220
Stock left pipe is what the center stand would normally come up against. I welded a stop, up near the pivot, works great with my 4-1.
The following user(s) said Thank You: Tulsa74136
  • Tulsa74136
09 Oct 2011 22:23
#482221
Any photos of your fix ??
All Stock
  • Motor Head
09 Oct 2011 22:26
#482222
Not tonight, but I can take a few tomorrow, if you want. If you have a Mig Welder(Hot Glue Gun) it will only take 1/2 hour to remove and weld the stop. Then repaint black, and refit, done.
10 Oct 2011 00:02
#482244
According to Kawasaki.com the 1980 KZ1000-B4 (LTD) did not come equipped with a centerstand. Some other 1980 KZ1000 models did have the stand. Perhaps another B4 owner can verify this. If your bike is indeed a B4 perhaps the previous owner added the centerstand but didn't think about fabricating a stop for it. Ed
Attachment KZ1000B4.jpg not found
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
10 Oct 2011 02:07 - 10 Oct 2011 02:12
#482280
My Vance and Hines 4-1 kit came with a small bar. It took me about 2 seconds to realize what it was for after installing the exhaust and pushing the bike out of the garage. It shouldn't be too hard to fab something like this out of a sturdy piece of sheet metal or steel bar (I shop at lowe's a lot lol).
Hope this helps you
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Last edit: 10 Oct 2011 02:12 by clutch. Reason: I can't type, or spell...maybe both!
  • tybolt99
  • tybolt99's Avatar
  • From where KZs came
10 Oct 2011 07:31
#482299
I put a little L bracket and rubber damper on KZ900. i didn't want to weld anything on.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
  • peter1958
  • peter1958's Avatar
10 Oct 2011 09:17
#482309
The center stand comes off very easy with 2 bolts. Just take it off and when you need too use it just slip the 2 bolts back in. Looks cleaner and less weight
  • H1Vindicator
  • H1Vindicator's Avatar
10 Oct 2011 10:34 - 22 Jan 2013 00:55
#482322
Last edit: 22 Jan 2013 00:55 by H1Vindicator.
10 Oct 2011 13:21 - 10 Oct 2011 13:24
#482340
H1Vindicator wrote: It seems like oiling the chain would be a major pain in the @zz without a center stand.
++1 Not to mention checking the oil level becomes a 2 person job unless you have a damn long neck :laugh: so I would be putting the centerstand on before every ride because that's when I check my oil. Also, when letting the bike idle or warm up while on the side stand the carbs aren't level so there may be uneven fuel flow. I use the centerstand 99.9% of the time. Ed
Last edit: 10 Oct 2011 13:24 by 650ed.
