gsxr swingarm
  • toad
  • toad's Avatar Topic Author
gsxr swingarm
09 Oct 2011 11:12
#482153
could someone let me know what year of gsxr swingarms are the easiest swap to a kz900.I have done the gs1100 before but like the looks of the gsxr swingers and I would just weld on shock mounting tabs for it.Are the older ones easier than newer?looking at a 160-180 tire. thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • testarossa
  • testarossa's Avatar
Re: gsxr swingarm
09 Oct 2011 11:40
#482155
1995 GSXR 750 fit my KZ1000 frame easily enough. I had to make bushings for the pivot, and weld in mount points for the upper shock mount, and lower linkage mount to use the mono-shock. I'm running a 180/55r17.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Boostable
  • Boostable's Avatar
Re: gsxr swingarm
09 Oct 2011 19:23
#482198
05 1000 fit my 82 with no issues, so I would assume just about any of them between 95 and 05 will work.. :)
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • superbovine
  • superbovine's Avatar
Re: gsxr swingarm
09 Oct 2011 19:33
#482199
I mocked up an 07 600/750 swinger the other day, fits ok but there is a bracket on the frame that needs to come off on the right side. It would need reducer bushings made of course, as the swing arm pivot bolt is much larger on the 07.
  • racer54
  • racer54's Avatar
Re: gsxr swingarm
09 Oct 2011 19:49
#482202
I've heard a Hayabusa arm is a close fit also.
  • toad
Re: gsxr swingarm
10 Oct 2011 08:40
#482302
ok thanks. Are they only 2 inches longer than stock?would the newer ones be longer than the older ones?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • testarossa
Re: gsxr swingarm
10 Oct 2011 08:55
#482305
toad wrote: ok thanks. Are they only 2 inches longer than stock?would the newer ones be longer than the older ones?
For reference, the 95 GSXR is 21 3/8" from the pivot centerline to the axle centerline. Obviously that length is dependent on where you have the chain adjusters set, but that's about the middle of the adjustment range. Not sure about the length of the newer units. One thing about the newer bikes is that if you want to go longer, then there are swingarm extensions sold for those bikes.
2004 ZX-10R
Angola, IN
  • purple_haze
  • purple_haze's Avatar
Re: gsxr swingarm
12 Oct 2011 03:46
#482712
i mocked up an 05 750 unit on a kz900 today and its about 1" longer than stock
the trouble with you is the trouble with me, you got two good eyes but still dont see...
jerry
  • Headly
  • Headly's Avatar
Re: gsxr swingarm
14 Oct 2011 05:35
#483108
i think mine was a L model late 80s early 90s ithink, same size axle and swingarm bolt bearings and is actually narrower than z swingarm so all you need is a washer each side to space it properly.
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
  • toad
Re: gsxr swingarm
14 Oct 2011 08:52
#483122
just picked up a brand new 97-2000 gsxr swingarm off fleabay for 90 bucks.it looks so shiny I couldn't resist,now to figure out the pivot shaft game
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
