need slightly longer rear axle....any ideas
- lambert II
08 Oct 2011 04:18
chopping my 82 spectre shaftie 1100, and need an axle long enough to go through the added axle plate on the left side.
82 kz1100d1 spectre
- mark1122
- Keep twisting it
Re: need slightly longer rear axle....any ideas
08 Oct 2011 08:16
what length and diameter?
i have heard that some old susukis have longer axles. i think it was a member named otakar, that said that.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
The following user(s) said Thank You: lambert II
- les holt
08 Oct 2011 08:57
I believe I used a 98 or 99 ZX6 rear axle. It ended up being perfect length although I have a custom built arm it may work for you. I can check the length for you this evening if needed.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- lambert II
08 Oct 2011 13:48
k ill try to find a micc to get teh dia, then pull it for length
82 kz1100d1 spectre
