Aftermarket brake lines
- bearshawk
29 Sep 2011 18:44
So guys those of you that have aftermarket brake lines, how did you run them? two straight lines going from the master or did you do the stock way going to the splitter?
im interested in upgrading the lines
thanks for any input!
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and pods
1998 honda superhawk 1000-fun in the twisties
1982 kz1100 A2 shafty, current project
- z1kzonly
Re: Aftermarket brake lines
29 Sep 2011 19:09
Simple, they sell them by the inch.
Banjo fittings in all different angles.
bolt em on and use whatever length you want, they screw together.
- steell
29 Sep 2011 21:19
I ran two lines from the master to the calipers, got rid of that stupid splitter.
But I also have a later model master cylinder with the brake light switch.
- ramtough_63
30 Sep 2011 00:02
noticed when looking online the fittings have different sizes AN4 10mm etc... how do I know what is what for a KZ almost ordered some then wasn't sure. The angles are easy just not sure about the fitting sizes
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- loudhvx
30 Sep 2011 01:39
I got rid of the splitter. For years I ran two lines from the master. But for the last few years I've been running a single line from the master to the right caliper, then a second line from the right caliper to the left caliper. Performance and feel wise, I can't tell the difference. But the routing is neater, and it may use a tad less tubing. The pads still wear the same amount on both sides.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- loudhvx
30 Sep 2011 02:00
I used all stuff from Earls. It's been about 10 years or so, but the part numbers may be the same. They warn not to use aluminum fitting for brakes. Only steel. The aluminum is much weaker.
I used their Speed Flex, -3 hose, .040" wall, with clear coat, 10 feet: 6100031ERL
Stock banjo height was 10mm. I used their .425" which is 10.8mm:
Straight: 600703ERL
30 degree: 600803ERL
Aluminum crush washers, 10mm: 177100ERL
Extra -3 olives: 699030ERL
Always get a few extra olives and washers.
Whatever you get, it is better to get all of the parts at the same place, and make sure the fittings are designed for the type of hose you are using. (There seem to be an infinite number of hose and fitting types. It's probably best to call the place and talk to someone with experience, as they will know what works with what.
Straight: 600703ERL
1981 KZ550 D1 gpz.
Other links.
Other links.
- Old Man Rock
30 Sep 2011 07:02
Can't say for stock master & splitter combo. In my build, due to ZX636 front end and master w/dual disk rotors, got rid of the splitter all together and went straight from master to right side caliper (w/longer banjo) and small brake line over to left caliper.... Pretty much the same config as the ZX configurations.
Speigler custom brake lines-fittings-Banjos.... Various options on fitting angles & colors in both lines and hardware.
spieglerusa.com/brakes/custom-brake-lines.html
Attachment SPeiglerBrakeLines.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- danonelson0109
30 Sep 2011 13:59
I converted my single disc front to dual. The splitter was included with all the other brake parts I got on Ebay so I polished it and used it. I got an Ebay Ninja master cylinder for dual disc use too.
I found that bleeding the brakes was a pain, but once I got it to firm up, there is plenty of stopping power. The key to bleeding the last of the air was to get it off the center stand and give it a lean to let the stubborn bubbles to come up to the top.
My concern with running 2 lines from the MC was that the outlet on the Ninja MC was directed toward the headlight rather than out the front and 2 banjo fittings would've been a tight fit with drag bars.
The single line down to one caliper and the hop over to the other is an interesting thought. I've seen it on modern bikes, but didn't cross my mind when I did the conversion a couple years ago.
Minneapolis, MN
1980 KZ650-E1 LTD
VM24 Carbs
Pod Filters
Vance & Hines 4 into 1
Dyno Jet Kit
Drag Bars
1980 KZ650-E1 LTD
VM24 Carbs
Pod Filters
Dyno Jet Kit
Drag Bars
- danonelson0109
30 Sep 2011 14:02
Oh yeah...I used SS Goodridge lines and banjos when I did the conversion.
Minneapolis, MN
1980 KZ650-E1 LTD
VM24 Carbs
Pod Filters
Dyno Jet Kit
Drag Bars
1980 KZ650-E1 LTD
VM24 Carbs
Pod Filters
Dyno Jet Kit
Drag Bars
