How wide is a 98-99 ZX9 Rear assembly??
  • ramtough_63
  • ramtough_63's Avatar Topic Author
28 Sep 2011 20:26
#480288
I already know this is a subject done to death however as usual my click finger gets happy on feebay and I buy things and then wonder if it will work.
aftermarket swingarm is 9.25 inches wide at the axle 2"over want to put a 98-99 ZX9 rear wheel with 180 tire can anyone tell me what the width of the assembled wheel is? I like the 00-02 6"wheel also.
Am I gonna need a wider swingarm to accomidate wheel rotor sprocket etc... also I have been told the front sprocket with a similar set up is 3/8 offset and looking through the archives I see 5/8 offset I will probably end up clicking on a 5/8 trying to collect the parts when I can get a deal on em
any guidence in this done to death subject is appreciated
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • purple_haze
  • purple_haze's Avatar
Re: How wide is a 98-99 ZX9 Rear assembly??
01 Oct 2011 20:20
#480834
?bump...i need the same info,will the 01 wheel work on the 99 swinger? do i need to make smaller spacers or use 01 spacers?
the trouble with you is the trouble with me, you got two good eyes but still dont see...
jerry
  • purple_haze
01 Oct 2011 20:22
#480835
i didnt realize you are using an aftermkt swinger, i will be using an oem 99 zx9r unit
jerry
  • ramtough_63
02 Oct 2011 13:01
#480933
how wide ID is your swingert at the axle that may help me
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • steell
  • steell's Avatar
02 Oct 2011 23:10
#481076
98-99 ZX9 C has 20mm axles front and rear.
00-03 (or so) has 25mm axle on front, and "I think" 25mm axle on rear.
90-93 ZX11C has 20mm axle front and rear
93-01 ZX11D has 25mm axle front and 20mm axle rear.
77-80 KZ1000 has 20mm rear axle
  • ramtough_63
02 Oct 2011 23:19
#481077
Thanks That helps next I need to know If The wheel complete with sprocket and rotor will fit this swingarm It is 9.25" wide inside(aprox 235mm) if it doesn't I am going to scrap this project and go Fat tire 230mm or bigger
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • purple_haze
05 Oct 2011 11:52
#481489
hey steell, ever time i see your avatar i lose complete train of thought, thanks!
jerry
  • purple_haze
08 Oct 2011 01:05
#481969
i just learned the hard way that a zx9r swinger is 10+" wide at the pivot point, im so glad i just bought a shock, linkage, rotor, cush, and axle
jerry
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
08 Oct 2011 08:21
#481986
purple_haze wrote: hey steell, ever time i see your avatar i lose complete train of thought, thanks!
do they look even bigger through those glasses. :woohoo:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • purple_haze
10 Oct 2011 02:35
#482286
they look HUGE, i see them in my sleep
jerry
  • ramtough_63
16 Oct 2011 18:34
#483564
any idea what year axles will fit a 99 zx6 rear wheel i measured the bearing it measured 1" i am assuming that is 25mm does anyone know what years use that axle is used. found one for an 03 with spacers and brakearm for an 04-06 for less than I can get the bare axle for a 99 was wondering if they are the same but cant get the lister to answer my email if anyone knows I appreciate the help thanks
Aaron
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
