KZ1000 lowering forks.
- 55fbomb
27 Sep 2011 23:54
I am going to be lowering my 77 kz1000 this winter, some shorter shocks with the GS swingarm and i would like to also lower the forks a good bit too. I have found in searching that other tubes can be use from 650s and 750s, is there a particular model that is the shortest, or another 1000 that had shorter tubes? mine is an a1 if that matters, thanks guys.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
- ramtough_63
Re: KZ1000 lowering forks.
28 Sep 2011 00:06
very interested in the same thing on a78 A2A On threar the nighthawk 550 shocks gave me bout 2 with the stock swungarm. My new aftermarket swingarm is 2" longer and has 2 spots to mount shocks (stock & about 2" back) but really would like to drop the front a little more
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- racer54
28 Sep 2011 00:09 - 28 Sep 2011 00:12
Instead of buying new forks, you can shorten your forks by putting in a spacer in your lower forks. Click on the link I have put in to show where you install the spacer. You can buy the spacer or you can make them yourself. You can buy them in 1" or 2" or 3" lengths to lower or shorten your forks by the same amount. You can buy these from
www.schnitzracing.com
among other places. Look under lowering links,blocks, straps in online catalog in the sub-catagories...
www.schnitzracing.com/manuals/KZ-GSLoweringBlocks.htm
Last edit: 28 Sep 2011 00:12 by racer54.
- ramtough_63
28 Sep 2011 00:13
Cool I need to put seals and new dust covers this winter might as well give it a shot Thanks!
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Last edit: 15 Feb 2013 11:51 by martin_csr.
- tachrev
- Rubber Side Goes Down
28 Sep 2011 09:57
I have a set of 750 twin forks I was going to use to lower my bike.
They are actually about 1.5" sorter then the stock(KZ1000A1) forks I had.
They fit right in my KZ1000 triple clamps, and the wheel worked too.
Build Thread
Build Thread
- Kidkawie
- I bleed premix
28 Sep 2011 11:33
Spacers, or limiters, are a good option because they can easily be reversed. Re Martin: I would be careful using shorter forks with the same travel because interference may occur.
I lowered the shock on one of my KX's. I used UHMW polyethelyne rod from McMaster. 2x12" rod was like $12 shipped. I just turned the spacer on my lathe. For shocks using a linkage it's basicaly a 3:1 ratio, so a 5mm spacer will drop the rear approx 15mm. since I lowered the rear, the geometry was off on the chassis so I needed to lower the forks too. I'm maxed out lowering the trees so I'm making some spacers for the forks over the winter.
To have the same spring rate you'll need to remove equal amount of the spacer from the spring seat. If you can't remove material from there then you can install shorter springs or cut the originals. Shortening the originals will give you a slightly higher spring rate though.
You will need less shock sag on a linkage system.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Jack
28 Sep 2011 11:48 - 29 Sep 2011 10:29
750 H2 2 stroke triple forks are same diameter but about 1.5" shorter than the Z1/KZ. Drop right into your trees and the caliper mounts line up too. Might check H1's as well, can't remember if they are the same. I have a set of S3 400cc. triple forks with upgraded springs/valving on my dragbike but that involves welding the Z1 stem to the lower S3 tree and using the S3 top tree as they are 34mm.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 29 Sep 2011 10:29 by Jack.
- 55fbomb
28 Sep 2011 17:45
Good info guys, so 750 twins and h2s, anyone know about 650 tubes? my tubes are useable but not as nice as i would like and the seals need done anyway so if i only find a good set of shorter tubes from another bike that is fine.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
- racer54
28 Sep 2011 19:05
I was told that the KZ650 forks are about 1 1/2" shorter and the same diameter as the KZ1000 fork tubes. I don't have any to measure but maybe some of out KZ650 riders can measure their tubes for ya.
28 Sep 2011 20:56
You can also just push the fork assemblies up in the triple clamps.
Last edit: 15 Feb 2013 11:46 by martin_csr.
