front sprocket sizes
- Godfrey
27 Sep 2011 21:24
Hey there, I was running 13 and 33 tooth sprockets, 630 o ring chain on my bike, and it seemed like it was running too many rpm, did a lil math and decided to get a 15 tooth front sprocket, problem is now though the chain clears the clutch rod, I'm unable to reinstall the chain guard between the sprocket and the clutch rod, I'm wondering(and I'm afraid I know the answer)if said guard is necessary? It seems odd that the manufacturers don't take such things into account when they offer these products, and I found it kind of disappointing, that at least the shop I deal with was unable to get much smaller rear sprockets.
Godfrey
Godfrey
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
- P21
Re: front sprocket sizes
27 Sep 2011 21:40 - 27 Sep 2011 21:42
your ratio is 13-33=2.54
Kawasaki KZ 1000 Police (2002) P21
Last edit: 27 Sep 2011 21:42 by P21.
- Godfrey
- Godfrey
27 Sep 2011 21:50
4500 rpm at 55mph seems excessive
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
- P21
27 Sep 2011 22:12
1978 kz650 comes with a 16 front and 42 rear set-up ratio is then 2.63
this is from some info i have written down
did you try a sprocket web site yet and see if they have anything
- P21
27 Sep 2011 23:01Godfrey wrote: 4500 rpm at 55mph seems excessive
4500 rpm should equal 60 mph with stock gearing and stock size rear wheel & tire. Take a look in the front of your Kawasaki service manual and you will find the Running Performance Curves chart which gives a detailed graph for all gears/rpm/speed/torque. Ed
- Godfrey
27 Sep 2011 23:38
yeah the tire is a 130/90 16, not a stock 650 rim
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
- Motor Head
27 Sep 2011 23:51
I didn't see where you said which bike you were working with, is this a more or less stock bike or the one with the Lopey cams?
You don't want to gear so tall that it takes you out of your powerband. @ teeth on the front will be quite a change, like as much as 800 R's. maybe 1 tooth would be better, and then you could fine tune with the rear.
- Godfrey
28 Sep 2011 00:02 - 28 Sep 2011 00:03
yes an 800 rpm drop was the plan, guess the motorcycle gods aren't gonna let me do that in spite of myself, lol, was hopin to find a 30 tooth rear sprocket but my supplier couldn't get one, that woulda brought it down to 4500 at 60mph
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
Last edit: 28 Sep 2011 00:03 by Godfrey.
- Motor Head
28 Sep 2011 00:03
Which bike was it?
- MFolks
28 Sep 2011 00:04
Sprockets And Drive Chains
www.sprocketspecialists.com/
www.sunstar-mc.com/home.aspx
www.rebelgears.com/
www.pmpsprockets.com/
www.schnitzracing.com
www.jtsprockets.com
www.pmfronline.com/counter_shaft_sprockets.php
www.dgchassis.net/
www.rebelgears.com/
www.jtsprockets.com
www.dgchassis.net/
