LTD front fender?
- paulie
LTD front fender?
17 May 2006 09:58
So one of the stays on the front fender of my '80 650F is bent.. and instead of trying to straighten them or find replacements, I was thinking of just replacing it with one of the fenders from a different model that is of the "floating" variety, meaning its attached near the fork, and does not require prominent stays like my bike. I like the cleaner look a lot better!
I've found one on the 'Bay from a 1980 550 LTD.. Does anyone have experience with doing a front fender swap and be able to tell me if it will fit? Or even perhaps which years/models fender would fit so I can narrow my search?
Looks like the fender I currently have is part # of 35001-1017, and the 550LTD fender i'm looking at is 35004-1047.
I found a lot of posts in the archives on front fenders, but none that address the fit specifically.
It seems that others have made this swap as well, and I may need to do some modifications to make it work, but any advice would be greatly appreciated!.
Thanks in advance!
Thanks in advance!
- steell
Re: LTD front fender?
17 May 2006 11:04
I can't help on the fender swap info, but I took the stay off the front fender on two 750 twins so far, and it has not caused a problem. But I do like the look of the shorter LTD fender
- rstnick
17 May 2006 11:57
I put an LTD front fender on, came from a 900/1000 originally. I liked the look as well. Then one day on a rainy group ride, my bike started dying. Eventually the engine conked out all together. With the shorter front fender, I was getting water spray up under my gas tank, and soaking my coils. When I pulled the tank, my coils were dripping with water. Luckily I had a small towel with me. I dried them off, and away I went.
I sprayed the coils with an electrical sealer, and have switched back to the stock fender, minus the stays(actually, the stay were removed about 15 years ago).
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- paulie
17 May 2006 12:04
wow, thanks for the replies guys, thats good info!
I guess I was not aware that I could just remove the stays and be fine..
have either of you noticed any extra vibration up front since removing those stays?
- rstnick
17 May 2006 12:09
No problems in 15 years, 30000 kms.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- ambergrismooon
17 May 2006 12:13
I'd remove the fender stay and then see if I could make the fender get into the tire. If I couldn't make the fender hit the tire I would be resonably assured but a big pothole could still deform that fender and if it hits in the rear of the tire I could see some bad things happening pretty darn fast. The shorter fender is certainly more rigid but a don't like to clean the front of my engine all that much or like rstnick says I like my coils dry. I put a sr fender on my 900LTD for just those reasons.
- paulie
17 May 2006 12:13
Excellent, I think this will be the route I take.. Especially since I can't say I like the prospect of water getting tossed up at the engine with a different fender..
Definitely will have to check out the rigidity of it all after doing so, just to be sure, definitely a smart plan
Thanks a ton you guys!!! Much appreciated!
Post edited by: paulie, at: 2006/05/17 15:15
- Rickman
19 May 2006 14:19
why don't LTD's soak the coils? do they have a different rake?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- rstnick
19 May 2006 14:24
The 900/1000/1100 LTDs engine is taller maybe, blocking more water flow.
Post edited by: rstnick, at: 2006/05/19 17:25
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- jtmcculloch
19 May 2006 14:44
if looking for another fender keep one thing in mind.
there are two very differant designs - dependng on if the front axle is at the bottom of the forks - or if it is in front of the forks.
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
