1982 KZ1000 lTD Wobble
- Observer
25 Sep 2011 21:50
New to the forum and I enjoy almost all the threads.
Quick question concerning the 1982 KZ1000. Does this bike have a history of a wobble at high speeds?
I owned a 1977 KZ (way back) which had a wobble and it was a simple fix with a change of shocks.
Re: 1982 KZ1000 lTD Wobble
25 Sep 2011 21:57 - 25 Sep 2011 21:58
Welcome to the madness!
I'd check things out in this order:
1. Tires (they can look good, be mounted & balanced right, and have correct pressure and still cause high speed wobble - this happened to me).
2. Swingarm pivot bushing/bearing play (lift rear wheel off ground; disconnect shocks; see if you can twist swingarm at all - you should not be able to)
3. Steering stem bearings (lift front wheel off ground and see if there is any fore and aft play - too lose; also see if handlebars can flop to either side with zero resistance - too lose; there should be only very slight resistance but they should not be sloppy.
4. Rear shocks
4. Rear shocks
Last edit: 25 Sep 2011 21:58 by 650ed.
- Observer
- Motor Head
26 Sep 2011 10:15
Also the front forks, same oil level, best to change it if you haven't, and same air pressure on each leg, about 8-10psi. Thats with no fairing. I run 13 with a fairing, and have added spacers for more spring pre-load. Same 82 K2 LTD. I have been getting a wobble from the rear under right corners since putting on a certain tire, Shinko Tour Master. Never had one before, so as Ed says, can be tires.
- MFolks
26 Sep 2011 16:09
I'll add my listing too:
I copied this from a post from Jeff Saunders(owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace is worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
Wheel bearings
