Help with forks not lining up
- kzed1972
23 Sep 2011 10:58 - 23 Sep 2011 11:05Attachment 2011-09-22_22-02-24_678.jpg not found
Kz1000 '78 Ltd bought some forks. They just don't seem to line up parallel. Have not bolted the lower tree just the top to hold them in and im freaking out. Am I missing something here
Attachment 2011-09-22_21-56-23_25.jpg not found
Attachment 2011-09-22_21-57-23_165.jpg not found
Last edit: 23 Sep 2011 11:05 by kzed1972.
- Motor Head
Re: Help with forks not lining up
23 Sep 2011 11:32
If you are suspecting a bent tube, loosen one side at a time and rotate the upper tube in the clamps. A dial indicator set up would show even a slight bend, but anything large you should see right away.
- bountyhunter
23 Sep 2011 14:21
On mine, the tubes were slightly tweaked. I loosened the tube clamps and rotated the tubes by hand. I found a point where the alignment was straight (to my eye). Maybe I had both bent tubes pointing the same way? Anyway, good luck.
- Kidkawie
- I bleed premix
23 Sep 2011 15:28
Your middle pic looks like the right tube is bent back. Switch legs in the trees and see if it looks the same or opposie.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- P21
23 Sep 2011 16:04
what happens when axle is put on?
Kawasaki KZ 1000 Police (2002) P21
- bountyhunter
23 Sep 2011 17:56 - 23 Sep 2011 17:56
If a tube is bent, rotate it by hand in the clamp and you will see the bottom end moving fore and aft as it turns.
Last edit: 23 Sep 2011 17:56 by bountyhunter.
- steell
23 Sep 2011 20:06
You have the fork tubes just hanging from the triple clamp, but you don't say if you just installed the triple clamps.
Has anyone ever installed a front end and "not" had to align the forks before tightening the pinch bolts?
23 Sep 2011 23:21Kidkawie wrote: Your middle pic looks like the right tube is bent back. Switch legs in the trees and see if it looks the same or opposie.
That's how it looks to me too. I would first loosen the right clamp and spin the tube 180 degrees to see if it still looks like it is bent back. If it does, you need to check the triple tree to make sure the bottom and top are true. If instead it looks like it is bent forward after spinning it 180, I would pull it out and check it on a flat surface to see if it is true. Ed
- mthure
25 Sep 2011 22:20
I have a piece of glass app. 2" by 14" (prolly 1/4" thick) that I lay flat against the forktubes to check for alignment. If there is the slightest amount of rocking available when holding the piece of glass against the tubes, I'll grab the handlebars and tweak them up against the steering stop (or hold the wheel between your knees) then recheck and repeat if necessary. It helps to have the bolts loose in only the top triple.
