Rotor Swaps or Aftermarket
- beaterbike
16 May 2006 20:22
Looking to change my KZ650 solid rotors for drilled - any swaps or aftermarket that bolt up?
- Sandy
- Fly High,Tony
Re: Rotor Swaps or Aftermarket
16 May 2006 22:59
Gotta drill?
Did Mine,and they turned out great!
Do a search in the archives...lots of info on doing it Yourself.
Good luck.
Good luck.
1977 KZ1000 A-1
- Samwell
17 May 2006 07:51
EBC makes rotors for your machine. I believe that they're drilled, but check to be sure.
www.ebcbrakes.com
Sam
beaterbike wrote:
www.ebcbrakes.com
Sam
- beaterbike
23 Aug 2006 17:31
poor braking problem solved??
One of the brake pads was covered with brake fluid...time for caliper rebuild.
