triple clamp help
  • xbmxxx
  • xbmxxx's Avatar Topic Author
triple clamp help
22 Sep 2011 22:53
#478824
I am attempting to start on a project using the spare parts from my first build. I have some spare triple clams and forks and a frame, but I cant figure out how it is all supposed to go together. Heres what I have.
also, no matter what I do, I cant get either of the bearings on the steering tube to budge, how do I snug them up in to the stem, any suggestions?
76 KZ750B Twin
  • testarossa
  • testarossa's Avatar
Re: triple clamp help
22 Sep 2011 23:40
#478848
Any idea what the triple clamp came from? It looks to be a one-off to me. Is it designed to fit a KZ?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
23 Sep 2011 00:45 - 23 Sep 2011 00:51
#478857
that dont look like any kz forks I've ever seen JMO
thats a cap nut on the upper in the photo, it aint gonna tighten up any more, if thats what ur asking,
after looking again, if ur bearings dont fit into the races then it aint gonna work, just guessing here but it looks like that aint even a set of jap triples
Last edit: 23 Sep 2011 00:51 by jonnybravo.
  • xbmxxx
23 Sep 2011 01:12
#478866
I have no idea. I think the only KZ part of the frame is the head tube. I figured out the bearing situation, the bottom one is threaded. It was just very very stuck.
I am not even sure what the forks are. The PO mentioned something about them being some sort of fake rake setup or something, but they look to be the same as the ones on my 750b, unless the length is a little different.
this is the best I can figure it out.
The lowest one is only a double clamp, so I have no idea what its purpose or proper location is.
76 KZ750B Twin
  • jonnybravo
  • Banned
  • Banned
23 Sep 2011 09:47
#478942
now it looks like something and ur probably right on the 750b, that lower one is probably a brace for stability, that would go just above the dust covers on the fork tube
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Sep 2011 12:56 - 23 Sep 2011 13:00
#478988
jonnybravo wrote: lower one is probably a brace for stability, that would go just above the dust covers on the fork tube
it can't go above the dust covers or it would keep the front end from working.
it has to be high enough that the sliders don't hit it.
see how this bike on the right has springs over the legs that rest on top of the sliders and the stabilizer/tweek bar give the springs something to push against?
Last edit: 23 Sep 2011 13:00 by 531blackbanshee.
  • jonnybravo
  • Banned
  • Banned
23 Sep 2011 14:31 - 23 Sep 2011 14:46
#479008
well I figured , yea my fork brace attaches to the lowers so that wasnt it, my bad, but u know what those came off ??? a springer front end, and somebody's adapted/attached tubes to em, look at the 2 holes in the bottom plate, thats where a rod goes through the springs,, its clamps on just below the upper tree and actually faces the other way, , just lose the bottom plate, if u dont use a front fender I would recommend a fork brace,
Last edit: 23 Sep 2011 14:46 by jonnybravo.
  • jonnybravo
  • Banned
  • Banned
23 Sep 2011 14:51 - 23 Sep 2011 14:51
#479012
here's a pic of mine, the plate between the spring is what ur lowest one is, looks like it was home fab setup (as is mine)so it looks slightly different but I think u see what I mean, thanx Leon for pointing out my error or I never would've guessed it :blush:
Attachment IMG_0772.JPG not found
Last edit: 23 Sep 2011 14:51 by jonnybravo.
