Front end conversion
  • kz_smurf
  • kz_smurf's Avatar Topic Author
21 Sep 2011 03:05
#478202
So I have a 1980 KZ1000 ST. Thinking of swapping the front end out for a newer style with clip on bars, new wheel, etc., in short, a whole new front end. Anybody know of any front ends that are compatible without too much fabrication? Thanks!
  • xbmxxx
  • xbmxxx's Avatar
Re: Front end conversion
23 Sep 2011 23:19 - 23 Sep 2011 23:25
#479087
There is some crotch rocket front end thats a pretty common swap. Its either a gsxr or a r6.
lemme google it real quick
www.kzrider.com/forum/5-chassis/417795-help-with-gsxr-fork-swap
EDIT
Just noticed yours is a 1000. I dont know if that makes a difference
76 KZ750B Twin
Last edit: 23 Sep 2011 23:25 by xbmxxx.
  • mthure
  • mthure's Avatar
25 Sep 2011 22:29
#479541
Down load the K&L supply catalog, find the section with steering stem bearings. Find the size of your bearings then compare to other bikes and what you can get your hands on. The stem diameter is the most important. Make swap.
www.klsupply.com/Home/2011KLcatalogQuickview.aspx
There is a PDF down load on the bottom of that page...
