kz750 csr forks (length)
  • 77easyway
  • 77easyway's Avatar Topic Author
20 Sep 2011 23:25
#478175
Need some pro info, what year kz runs a slightly shorter forks than my 82 twin csr? Maybe 1-2" shorter,
Or a slighter shorter spring that would fit in my stock fork tubes. Thanks guys
  • martin_csr
  • martin_csr's Avatar
Re: -
21 Sep 2011 09:56 - 15 Feb 2013 11:35
#478253
Last edit: 15 Feb 2013 11:35 by martin_csr.
  • 77easyway
Re: kz750 csr forks (length)
21 Sep 2011 13:03
#478326
yes this is true, but not very much (maybe 1/2" at best ) due to the air nipple to fill shocks up, looking for mor around 1-1.5" . R kz550 or 650,700 forks shorter ? thanks
21 Sep 2011 13:26
#478335
77easyway wrote: Need some pro info, what year kz runs a slightly shorter forks than my 82 twin csr? Maybe 1-2" shorter,
If you drop the front forks your handling will be affected. If you drop the front and rear you may find things scrape if you run through turns fast. Are you doing this for cosmetic reasons or is the bike too tall for you to hold it up easily?
  • martin_csr
Re: -
21 Sep 2011 13:57 - 15 Feb 2013 11:35
#478343
  • 77easyway
21 Sep 2011 19:32
#478407
Will do, ill check on the750E forks, seems like a possible alternative. Thanks
  • steell
  • steell's Avatar
21 Sep 2011 23:12
#478478
I have a set of KZ750E forks, and a set of 1980 KZ750G twin forks, so if you need length measurements I can probably get them.
Both are 36mm
  • steell
  • steell's Avatar
22 Sep 2011 16:52
#478671
KZ750E forks measured 30"
78-80 KZ750 twin forks measured 31"
  • 77easyway
24 Sep 2011 22:48
#479316
Thanks for the lengths,
