Bizarre non-availaibilty of Z1R brake part
  • 300kph
  • 300kph's Avatar Topic Author
20 Sep 2011 22:08 - 20 Sep 2011 22:10
#478155
I've been working on a pretty complete resto of a 1978 D1 (Z1R)
I've called virutally every dealer that ever comes up in Quickstar (or whatever that software program is that helps Kawai dealer share info) and just recently found some Rear master Cyl. parts I needed after realizing my whole assembly went missing.
Here's what's weird: I got a new cap, diapgragn and plate and found a very clean body and resevoir and pieced together a new-ish looking master cyliner unit but the resevoir is pretty discolored from age. I thought it might be nice to find a new one to show off when I popped the side cover.
This part does not seem to exist... Check the parts fiches and you'll see there is simply no part number for it.
The D3 (1980 Z1R) shows one but NOT the 1978... I also beieive the 1979 LTD and 1978 Z1R share a common master cyl unit and the fiche for the LTD also does NOT show a part number for it either.
It's freaky... they show the part yet do not name it or acknowledge it.
I suppose the only way one would get one is if you could find a complete assenbly (and trust me... there is not one ANYWHERE... I looked EVERYWHERE!)
Thoughts anyone?
Wayne
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
Last edit: 20 Sep 2011 22:10 by 300kph.
  • z1kzonly
  • z1kzonly's Avatar
Re: Bizarre non-availaibilty of Z1R brake part
20 Sep 2011 22:48
#478168
Your looking for the white plastic resovoir?
How about a picture of it. Do you need the one that is solid in the housing or the one that has the rubber feed line?
Tip! I have sold restored stuff on ebay for 11 years.
Try soaking it in BLEACH!
I cleaned up a Z1 chain oil tank once, it made it look like night and day difference.
  • RonKZ650
  • RonKZ650's Avatar
21 Sep 2011 00:00
#478177
Common thing. You buy an entire new master cylinder to get the part. No longer available of course, but when it was, that is what was done.
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
21 Sep 2011 00:17
#478181
Had the same problem attaining a rear m/c kit,and front m/c diaphragm for my 80z1r.
There just not available anywhere. :huh:
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
The following user(s) said Thank You: 300kph
  • eddiem
  • eddiem's Avatar
  • KZR FLAG RELAY CARRIER #63
21 Sep 2011 00:47 - 21 Sep 2011 00:49
#478185
isn't the kz's the same m/c ? rear one?
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Last edit: 21 Sep 2011 00:49 by eddiem.
  • 300kph
21 Sep 2011 04:04 - 21 Sep 2011 04:08
#478203
The white plastic reservoir that pushes into the the cylinder assy. See the picture. The part has no number. Nor does the stand-alone cylinder for that matter.
I soaked it in bleach for 3 days and it did not lighten one bit.
Can anyone post a picture of the master cylinder assembly as appears on the bike please? My cylinder is silver and unpainted, yet I've seen used ones that are black.
I found a new cap and a used complete assy. from which I can grab the diaphragm and possibly it will have a whiter reservoir. We'll see.
I just find it odd that they never listed the reservoir as a part.
Thanks all.
Wayne
1978 Yamaha XS1100
Last edit: 21 Sep 2011 04:08 by 300kph.
  • 300kph
21 Sep 2011 04:11 - 21 Sep 2011 04:12
#478204
I also found lots of places that had the cap or the diaphragm... some would not ship to Canada and one pirate wanted $32.50 to mail the plastic plate that weighs about 2 grams and is thick as a silver dollar.
Another place had all 3 parts but simply would not ship to Canada.
The used cylinder assy. arrives this week and my new cap is enroute.
W
1978 Yamaha XS1100
Last edit: 21 Sep 2011 04:12 by 300kph.
  • wireman
  • wireman's Avatar
21 Sep 2011 06:49
#478221
if you find a place that has the parts but wont ship to canada let me know and you can have them ship it to me then ill repackage it and ship it to you B)
  • martin_csr
  • martin_csr's Avatar
Re: -
21 Sep 2011 15:32 - 15 Feb 2013 11:36
#478362
Last edit: 15 Feb 2013 11:36 by martin_csr.
