brake upgrade
- bearshawk
brake upgrade
12 Sep 2011 11:24
so guys, i just upgraded the brakes on my honda vtr and i have the spare set just laying around, could i swap out the master cylinder from my kz to the VTR1000 one? my MC on the 650 is pretty crappy... its leaking a bit, i did just replace the cracked cap and its better but i just was wondering. have people have swapped out to the newer style MC?
thanks a bunch
thanks a bunch
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and pods
1998 honda superhawk 1000-fun in the twisties
1982 kz1100 A2 shafty, current project
Last edit: 15 Feb 2013 11:37 by martin_csr.
Re: brake upgrade
12 Sep 2011 13:53
master cylinders and calipers need to be matched up.
Front Master Cylinder to Wheel Cylinder
Ratio Chart
www.vintagebrake.com/mastercylinder.htm
hth,
Ratio Chart
hth,
- bearshawk
Re: brake upgrade
12 Sep 2011 14:59
how does this chart matter for me leon? am i looking for a specific number on the chart? i get the mc bore size and the caliper pistons but the insides of the chart what am i looking for. the mc i will be using is from a 98 vtr1000 i believe its 5/8ths and from a 7/8ths clip ons
the vtr MC is 14mm and the calipers are 32mm/30mm
- steell
- bearshawk
Re: brake upgrade
12 Sep 2011 15:05
i have read that, thats the reason i decided to go with my rc51 brakes on the VTR, what i dont get is, will the VTR MC effect my kz in a negative way? the mc i have for the z right now is pretty leaky and i thought since i have the vtr's layin around i would give it a try, and it has an adjustable lever which i like
Re: brake upgrade
12 Sep 2011 15:45 - 13 Sep 2011 09:45
laymans terms.
too big a master cylinder may not apply enough force to stop you.
too small may apply too much force and cause you to lock up the wheel.
in other words if you don't know how to figure out if your master cylinder and calipers are matched to each other,you should keep the master cylinder and calipers matched as they came off the bikes.
just throwing the m/c off one bike on another "because it don't leak"could cause you a problem.
brake problems can be fatal.
hth,
hth,
Last edit: 13 Sep 2011 09:45 by 531blackbanshee.
- bearshawk
Re: brake upgrade
12 Sep 2011 16:02
so what is the "correct" ratio? the stock one for the kz? so as close to 6.67 as possible? it seems like the matchup for the vtr's is 8.85.
i am just trying to learn how to make good decisions and i do know brakes are something not to be taken lightly thats why i am asking as much as possible before i do anything in hopes that someone had tried using a modern MC on their bike.
Re: brake upgrade
12 Sep 2011 16:09
good question
for someone smarter than me
- steell
Re: brake upgrade
12 Sep 2011 20:29 - 12 Sep 2011 20:34531blackbanshee wrote: laymans terms.
too small a master cylinder may not apply enough force to stop you.
too big may apply too much force and cause you to lock up the wheel.
hth,
You do realize that you have that backwards?
Smaller master cylinder = more force
Larger master cylinder = less force
At the caliper.
5/8" = ` 15.5mm
What I want are F4i calipers with the VTR master cylinder, been looking on eBay.
I use a 15mm ZX11/GPZ1100/ZG1000 master cylinder with 83 GPz750 calipers on my 750 twin and love the braking power.
14mm would make your brakes touchy, as in one finger lock up. 15mm would be much better.
I have an extra 15mm master cylinder, want to swap?
Last edit: 12 Sep 2011 20:34 by steell.
Re: brake upgrade
13 Sep 2011 09:45steell wrote:531blackbanshee wrote: laymans terms.
hth,
At the caliper.
thanks for clearing that up.
- bearshawk
Re: brake upgrade
13 Sep 2011 13:54
what is your MC from?? i would definitely be intersted!
