Help !! Frozen Brake Pedal
  • Tulsa74136
  • Tulsa74136's Avatar Topic Author
09 Sep 2011 21:30
#475512
My rear brake pedal is stuck on the shaft it pivots on. Nut & washers have been removed. There is some up/down movement...but minimal. Tried heating with a torch (not to the point of being red hot, but warm) seems to be getting worse.....anyone got any suggestions ??
Todd
1980 KZ1000 - B4 LTD (12/79 Mfd Date)
PODs, Kerker Header, Mikuni 29mm Smoothbores
Vetter Windjammer Fairing & Trunk
1981 KZ1000 - M1 CSR (03/81 Mfd Date)
All Stock except for PODs
1981 Yamaha XJ550H Maxim
All Stock
1977 KZ400 - D4 (2012/13 Winter Project) SOLD
Re: Help !! Frozen Brake Pedal
09 Sep 2011 21:49 - 09 Sep 2011 22:08
#475516
Tulsa74136 wrote: My rear brake pedal is stuck on the shaft it pivots on. Nut & washers have been removed. There is some up/down movement...but minimal. Tried heating with a torch (not to the point of being red hot, but warm) seems to be getting worse.....anyone got any suggestions ??
Todd
Drench in Kroil or 50-50 ATF/acetone solution, or Liquid Wrench or PBBlaster, several periodic applications, allow to soak at least overnight, or longer, keep allying the penetrant at intervals.
Could later try using a gear puller, or applying pressure from the rear while hitting the shaft.
Good Fortune! :)
Last edit: 09 Sep 2011 22:08 by Patton.
The following user(s) said Thank You: Tulsa74136
09 Sep 2011 22:42 - 09 Sep 2011 22:43
#475523
+1 Drench with Kriol for 2 days. it'll come off easily.
www.kanolabs.com/
Last edit: 09 Sep 2011 22:43 by 650ed.
  • wireman
  • wireman's Avatar
10 Sep 2011 00:24
#475558
the mother of all lubes! :woohoo:
Attachment zep45_v2.jpg not found
  • Tulsa74136
15 Sep 2011 20:35
#477124
Thanks for your responses. Friday & Saturday continued spraying with PBblaster. Sunday I started moving it as much as possible....thought I was going to have a stroke, seeing how I was all bentover, giving it all I had. Finally I got a little more movement out of it, 90 minutes later I finally got it off.....crap!!! That was work !! Cleaned it up, lubed with some grease & it works great. Bled the brakes and finally took the bike on a maiden voyage around the neighborhood. It's first time on the street in 20 years.
All Stock
