Chain tighter in one spot
  • BIGD
  • BIGD's Avatar Topic Author
09 Sep 2011 15:57
#475430
As the wheel is turned the chain will become very tight and make a noise in one spot. Continuing the rotation will loosen the chain again until it reaches the same spot. Alignment marks on both sides are in the same position, and visually there seems to be no problem. Chain is well lubricated, and the sprocket does not seem to have a high spot. thanks Don
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Chain tighter in one spot
09 Sep 2011 16:03
#475431
this is very common. u have a stretched section in your chain.
the best advice is to replace the chain and both sprockets at the same time.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • bountyhunter
  • bountyhunter's Avatar
09 Sep 2011 20:44
#475504
That's how chains tell us that they have gone to chain heaven and need to be replaced.... ;)
  • gane
  • gane's Avatar
10 Sep 2011 01:37
#475585
Don, A little of this, a little of that. Chains develop "tight spots" the causes are various. The most common being setting for prolonged periods. the area where the chain encircles the c/s sprocket rusts in place.& can usually be discerned by a "hoop" visual in the "long run" between sprockets.(where tight spot occurs) So far, this is just a chain issue. for grins, rotate rear wheel til chain is "slack". then attempt to pull chain away from rear sprocktet "about the middle of rear of sprocket". if you discern "Any" slack, or visual wear of teeth on sprocket, it's time for a "set". depending on how "cheep" you are, a "Kinked" chain may be salvaged by soaking in solvent/kerosene/pepsi & use. Again , for "grins" feel a couple of "rollers" The cylinders within chain links which contact the valleys of sprockets, they should spin freely, but have no discernable "play". if no wear to sprockets but "play" exists, Rec. install a cheep "new non-oring" chain, & ride,,,, If adjustment becomes an issue, replace with a "quality set". Bikes of our vintage/use seldom see the demands placed upon them when new. (which in the day was @ 20 K) I converted to 530 @ 5k miles ago, & have made 2 minor adjustments. (abet w. steel sprockets & renthal O ring chain) just my 2 cents...G
[img][/img] 1977 KZ1000A1
