GPZ front brakes
  • baldy110
  • baldy110's Avatar Topic Author
GPZ front brakes
06 Sep 2011 18:08
#474697
I have a set of 279mm front brake rotors that bolt up the early 80's gpz style front rim. according to the manuels I have the GPZ bikes had rotors of 260mm. Does anyone know what had the 279mm rotors maybe a later GPZ? Thanks
  • MFolks
  • MFolks's Avatar
Re: GPZ front brakes
06 Sep 2011 18:40
#474704
Kawasaki Brake Disc Measurements
Z1100A1-A3 shaft. Front disc =236 mm, rear disc= 236 mm.
GPz B1 twin shock model. Front disc = 236 mm, rear disc = 236 mm
GPz B2 twin shock model. Front disc = 246 mm, rear disc = 236 mm
Z1000J. Front disc =236 mm, rear disc =236 mm
GPz 1100A1-3. Front disc =246 mm, rear disc =236 mm.
However, the unitrack discs look different in design/style to the B2 ones. Worth a closer look to see if the mountings are the same though.
And an expanded listing of compatable disc's for several models(I believe the "K" listings are for EBC brake systems part numbers)):
Kawasaki Brake Disc Sizes
BRAKE DISC ROTORS:
Brake disc: KD1
FRONT Z250A3 Z400J12/J3 Z440D/H Z550A2/A3 Z550C1/C2(LTD) Z550D1(GPZ) Z650F2/F3/F4 Z750R1(GPZ) Z750E/L/H GT750-SHAFT VN750A
Brake disc: KD2
FRONT EN450A EN500A/B GT550G-SHAFT Z1000J1/J2 Z1000K1/K2 GPZ1100B1 Z1100A1/A2/A3-SHAFT
Brake disc: KD3
FRONT Z1000J3 Z1000R2 GPZ1100B2
Brake disc: KD4
FRONT GPZ500S ER-5 ZX750G (GPZ750R) ZX750E1/E2 (TURBO) GPZ900R-A1-A6 GPZ1000RX ZL100A-ELIMINATOR ZX1100A1/A3 (GPZ)
Brake disc: KD5
FRONT ZX400C2 GPZ600R ZX750A1-A5(GPZ) GTR1000 A1-A7
Brake disc: KD6
FRONT KR1-S ZZR250 ZXR400H ZR550B-ZEPHYR ZL600B-ELIMINATOR ZX6R-F1-F4 ZZR600D/E ZR750C/D-ZEPHYR GPZ900R A7-A11 GTR1000 A9-A14 GPZ1100E/F
Brake disc: KD7
FRONT ZXR750H1/H2 ZR1100A/B-ZEPHYR ZRX1100C ZZR1100C1-C3
Brake disc: KD17
FRONT ZXR750J1/J2 K1 L1/L2/L3 M1/M2 ZX7-R P1/P2/P3/P4/P5/P6 ZX7-RR N1 ZX9R-B1/B2/B3 ZZR1100D1-D7
Brake disc: KD8
FRONT ZX10-ZX1000B 1988-1991
Brake disc: KD9
REAR ZX400C2 ZX550A1-A5(GPZ) ZX750A1-A5(GPZ) GPZ1000RX
Brake disc: KD10
REAR Z550D1 (GPZ) Z750R1 (GPZ) GT750P-SHAFT Z750E/H/L
Brake disc: KD11
REAR Z1000J1/J2/J3 Z1000K1/K2 Z1000R2 GPZ1100B1/B2 Z1100A1/A2/A3-SHAFT VN1500B2
Brake disc: KD12
REAR GPZ600R GPZ900R A7-A11 ZX10 B1-B3 ZZR1100C1-C3
Brake disc: KD13
REAR ZXR400H ZX-4 ZXR400L ZR550B-ZEPHYR ZZR600E GPX750R ZR750C/D ZEPHYR
Brake disc: KD14
REAR ZXR750H/J/K/L/M ZX7-R P1-P6 ZX7RR-N1 ZX9-R B1-B4
Brake disc: KD15
REAR ZZR1100D1-D7
Brake disc: KD16
REAR ZX750G (GPZ) ZX750E-TURBO GPZ900R A1-A6 ZL1000A-ELIMINATOR ZX1100A1/A2/A3 (GPZ)
  • baldy110
09 Sep 2011 14:05
#475404
OK, after much research I found out the 1983 GPz750 turbo model wsa the only GPz series with 280mm front brakes, actually 279.40mm. I guess that is the set I have.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
09 Sep 2011 14:36
#475409
So, we know the larger rotors fit on an early big GPz...are you running the stock brakes or did you have to upgrade to the later brakes?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • baldy110
09 Sep 2011 17:19 - 09 Sep 2011 17:21
#475463
No, the big GPz's had the same size rotors and used the same calipers as the GPz750's. I bought an 82 GPz750 about 7 years ago for an ELR clone project. The 750 had been raced back in the day and had safety wire all over it and a bunch of performance mods. Well I have finally gotten around to finishing the project and when I re-installed the front brake rotors which came on the bike my GPz1100 calipers did not fit. The caliper carriers were to short. I measured the rotors and found out they were 279.40mm. I measured the rotors from the 1100 and they measured 260mm. I figured the previous owner who raced this bike back int he 80's must have installed the 83 GPz750 turbo rotors and brakes for better braking. Probably one of those cheap upgrades back in the day. I figured since the rotors are larger they should work better than the smaller ones so I will use them.
Last edit: 09 Sep 2011 17:21 by baldy110.
  • DFIGPZ
  • DFIGPZ's Avatar
10 Sep 2011 16:14 - 10 Sep 2011 16:14
#475694
I think you will find that the 1984/85 750 turbo and the 1983/84 gpz 1100 take the same rotors i have both and rotors are the same.
1984 750 Turbo
Last edit: 10 Sep 2011 16:14 by DFIGPZ.
  • M357.5
  • M357.5's Avatar
  • Kwakas N' lots of em'
10 Sep 2011 18:18 - 10 Sep 2011 18:20
#475743
82 rotors ( 7 spoke rims ) have 7 rotor bolts. The 83 and up Uni-Track models with 3 spke wheels all use 6 rotor bolts. Therefore I highly doubt they are from a Uni-Track bike, cuz they do not interchange.
Although you will find that the 7 spoke REAR rotors are 280mm and have the same bolt pattern as fronts...you can bolt them onto the front wheel if memory serves correct. They are thicker than the fronts though.
Both my 1985 GPz900R and my 84 ZX750E1 Turbo use 280mm front rotors, WITH 6 bolts ( the drill pattern is diferent between these models but do interchange )
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Last edit: 10 Sep 2011 18:20 by M357.5.
