Stupid Question?!
  • badrhino
  • badrhino's Avatar Topic Author
Stupid Question?!
06 Sep 2011 13:34
#474630
Which side goes out on this rear sprocket? They don't tell you and one side is flat the other has some detail. I'm guessing flat side out.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Stupid Question?!
06 Sep 2011 13:53
#474635
My guess is flat side out since that's the side with the tooth count stamped in it.
I'm sure someone will correct me if I'm wrong though.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • rcarver
  • rcarver's Avatar
06 Sep 2011 14:11
#474642
my manual says to place the tooth count stamp towards the outside.
1979 KZ650 SR (aka: Stella Blue)
  • martin_csr
  • martin_csr's Avatar
Re: .
06 Sep 2011 14:19 - 22 Jan 2013 04:28
#474645
Last edit: 22 Jan 2013 04:28 by martin_csr.
  • badrhino
06 Sep 2011 14:20
#474646
That's what I thought, but thought I would make sure.
Franken Z!
