Tire size
- baldy110
Tire size
05 Sep 2011 22:50 - 05 Sep 2011 22:51
I have a 82 GPz750 rear rim, 2.15" I would like to install a 150/70x18 tire on it. Will this tire fit. Thanks
Last edit: 05 Sep 2011 22:51 by baldy110.
- otakar
Re: Tire size
05 Sep 2011 22:57
NO a 3.5" is the MINIMUM you would require for that tire. 4" would be the ideal.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Re: Tire size
05 Sep 2011 23:23baldy110 wrote: I have a 82 GPz750 rear rim, 2.15" I would like to install a 150/70x18 tire on it. Will this tire fit. Thanks
No; it won't fit. The largest you can shoehorn on that rim (it's the same size as the rim on my KZ650-C1) is a 130/90V18. I ran the 130 size for years, but frankly they do not work any better than the 120/90V18 size tires which I've been using for the last 12K miles. The reason is that the narrow rim pinches the 130 size tire bead in so tight that it deforms the tread cross section leaving no more usable tread than the 120 size. The 130 looks cool (nice and beefy) but from a performance perspective there's no gain, and they really are a struggle to mount (especially with a tube and 2 bead locks on my bike). I don't believe it would be physically possible to squeeze anything larger than a 130 on a 2.15 rim. Ed
