will a 140/90 work on a stock '78 kz1000 rear
- kzed1972
05 Sep 2011 21:42 - 06 Sep 2011 16:37
I bought these rims with tyres. The front has good tread and is 90/90. The rear is a 160/90 with a spacer to clear the chain. Im want to go with a smaller rear tyre and try to match up the rear tread with the front. I can only find a 140/90 for the rear. I know the stock rear mag is 130/90. Just need opinions if going up 10mm is okay and if it wont interfere with the chain.
I have a 1978 kz1000 LTD B2. With stock mag wheels. Front rim is 19 and rear is 16
Last edit: 06 Sep 2011 16:37 by kzed1972.
- otakar
Re: tyre size- help please
05 Sep 2011 22:54
These are the best tires made for the money you will pay. Do NOT use the old tire on the rim. bike tires are good for only at most 4 years mounted and about three years exposed to sun light. Front should be a 1.25-19(you can mount the wider 90/90-19 if you wish) The rear should be a MT90-16.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
