Best way to clean up surface rust from rotors?
  • badrhino
  • badrhino's Avatar Topic Author
02 Sep 2011 01:22
#473701
What is the best way to clean up the rotors? They seem to be in good shape but just have a little light surface rust in some spots from not being used for so long.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • elfmagic17
  • elfmagic17's Avatar
Re: Best way to clean up surface rust from rotors?
02 Sep 2011 01:26
#473703
Ride the hell out of it!! LOL, But seriously just take it for a ride that should clean it off good, if your worried about your pads then take a scotch brite pad to them.
Kenny Hicks
74 Honda CB550
  • MFolks
  • MFolks's Avatar
02 Sep 2011 01:29
#473705
Brown or green scotchbrite pads(dry)do a good job of removing rust.
  • bountyhunter
  • bountyhunter's Avatar
02 Sep 2011 04:23
#473717
If the rotors are off the bike: I got a new fine grit sharpening (oil) stone and faced mine lightly by hand. It smooths down the tops of the ridges a bit but doesn't remove anything from the flats.
  • wireman
  • wireman's Avatar
02 Sep 2011 04:27
#473718
glass bead/soda blasting B)
