master cylinder
- gengomerpyle
master cylinder
01 Sep 2011 18:21
how hard is it to rebuild the front master cylinder on a 750R1? right now it goes in when i brake but the piston doesnt come back out.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- z1kzonly
Re: master cylinder
01 Sep 2011 19:58
You can buy a rebuild kit for $30.00.
Yopu can sand out your bore, and find that it is pitted.
So your cyl. is wiped out and you just wasted $30 bucks on a kit.
So now you either bore out your cylinder to a bigger bore or buy a new replacement.
Sorry to break the news to you WTF?
If only factories used dot 5 silicone brake fluid, no one would have this problem.
Just my opinion
Just my opinion
- gengomerpyle
Re: master cylinder
10 Sep 2011 16:30
i ordered a rebuild kit and got lucky when i took my old one apart. it had some oxidation under the rubber boot at the washer and it was causing the piston to not release. i was able to clean it and there were no pitting inside the cylinder. it took me all of about 10 minutes to rebuild it. now i have a very strong front brake. it was a lot easier then i thought it would be.
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
