Brake part needed
  • djturnz
  • djturnz's Avatar Topic Author
Brake part needed
31 Aug 2011 21:29
#473375
I need to replace my rear pads. Thats no problem. The issue is, I also need the little sheet metal clip that holds the pads. Mine is bent. Z1E doesnt show that as a part they carry.
1982 KZ750 (4) LTD
  • GPz550D1
  • GPz550D1's Avatar
Re: Brake part needed
31 Aug 2011 21:58
#473381
According to Kawasaki.com, there are a guide,pad and spring,pad that is used on your rear brake. You can go to Kawasaki.com and look at the picture and part number for what you need. The parts show to be active numbers from Kawasaki.
1981 KZ550-D1
  • wireman
  • wireman's Avatar
01 Sep 2011 00:23
#473394
can you straighten yours? B)
  • martin_csr
  • martin_csr's Avatar
Re: -
01 Sep 2011 09:25 - 15 Feb 2013 11:37
#473470
Last edit: 15 Feb 2013 11:37 by martin_csr.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
01 Sep 2011 10:17
#473483
+1 on sending Z1E and email. They helped me out HUUUGE on my oil pressure sending unit wire boot.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
