Stipped.....
- mrxtreme3
Stipped.....
29 Aug 2011 00:18
I own a 1970 Kz 650 and Today i was tightening my bike chain, and when I was i began to tighten up the bolts that tighten up the bolts that tignten up the chain( idk if that makes sense, best i could explain it) and it stripped the threads on the inside of the frame. is it done for? are there anyways to fix this? \
- wireman
Re: Stipped.....
29 Aug 2011 15:34
That bike should be in a museum,only 1970 kz 650 in existance im aware of! :woohoo:
can you post a picture of which bolts youre talking about?
- mrxtreme3
Re: Stipped.....
29 Aug 2011 23:03
oops typed a 9 instead of a 0, its a 1979.. here they are also, Im in need of a drive chain. Any help that you can give me on how to do that?? My camera got smashed so I'm unable to but, you know the bolts you use to tighten the drive chain on the left and right? It's the one on top of those to tighten those up.
- roy-b-boy-b
Re: Stipped.....
29 Aug 2011 23:11
If you are talking about the piece on the end of the swingarm that has a dimple in it,then you can just get that piece or get a long enough bolt to go all the way through. Roy
- wireman
Re: Stipped.....
29 Aug 2011 23:32
are you talking about the pieces on my avatar? those are chain adjusters
Re: Stipped.....
29 Aug 2011 23:34wireman wrote: That bike should be in a museum,only 1970 kz 650 in existance im aware of! :woohoo:
Maybe the pic below will help. Which bolts are you having the problem with, and did you use a torque wrench when tightening them or were you doing it by "feel"? Ed
Attachment kz650C3Swingarm.jpg not found
The following user(s) said Thank You: mrxtreme3
- wireman
Re: Stipped.....
29 Aug 2011 23:37
before trying to adjust 20/21 you need to loosen the axle bolt and nut
Re: Stipped.....
29 Aug 2011 23:40mrxtreme3 wrote: ...in need of a drive chain....
Would consider Z1 Enterprises
