caliper dragging on KZ750 twin
  • makenzie71
  • makenzie71's Avatar Topic Author
27 Aug 2011 19:04
#472190
We thought the piston was sticking...but it's not. We popped it out and it's clean, the seals are pretty, and the passages are clear. But the piston doesn't push back and it drags the rotor.
The master cylinder isn't new, but I pulled it directly from another bike (swapped out to a newer radial master) who's brakes were working beautifully.
Any ideas?
  • Motor Head
  • Motor Head's Avatar
Re: caliper dragging on KZ750 twin
27 Aug 2011 19:08
#472191
Open the bleeder, or crack the line to see if there is any pressure left. Shouldn't be any. Possible return port in Master blocked.
  • makenzie71
27 Aug 2011 19:09
#472192
No pressure on caliper without the lever being drawn...it's bleeding back properly.
  • Motor Head
27 Aug 2011 19:18
#472196
Caliper slides, where it mounts with 2 bolts, free/ lubed? It should slid back and forth. Try just that without pads. Just don't pull the brake lever. Maybe push the piston back again.
It is the Square cut O-ring, that will move the piston back, just a bit, when pressure is released. Did you replace any of the caliper seals?
  • bountyhunter
  • bountyhunter's Avatar
27 Aug 2011 20:16
#472206
Motor Head wrote: Caliper slides, where it mounts with 2 bolts, free/ lubed?
That's what was hanging up on mine. I removed each mount bolt (one at a time) and greased and re-inserted. Afterwards the caliper slid easily on the pins.
