Removing chrome grips without damaging them
  • Topper
  • Topper's Avatar Topic Author
27 Aug 2011 14:32 - 27 Aug 2011 14:57
#472152
Need some help figuring out how to get these off without doing any more damage than I already have.
I've got grips like this:
And I need to get them off, but intend to put them back on again. I've tried channel locks with a towel protecting the grip. It still chewed up the grip and it barely budged.
I've sprayed some WD-40 between the grip and the bar. The problem is getting a good enough "grip" on the grips without damaging them.
Any suggestions?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Last edit: 27 Aug 2011 14:57 by Topper.
  • P21
  • P21's Avatar
Re: Removing chrome grips without damaging them
27 Aug 2011 15:33
#472162
i had a set on my harley
tried to save but no luck had to cut ribs off with pair of cutters
the more you sqeeze the chrome part the tighter it gets
Kawasaki KZ 1000 Police (2002) P21
  • Charlie650
  • Charlie650's Avatar
27 Aug 2011 15:44 - 27 Aug 2011 15:50
#472164
The RH side should come off the bars with the throttle sleeve.
To get the left side off without marking it, you need an airline with a duster gun or similar on the end.
Shove the duster gun inside the handlebar where you've just puled the throttle sleeve from and mask off around it as much as possible with your hand or a rag whatever, to stop all the air escaping from the duster end and squeeze the trigger.
It will blow your other grip straight off the bar so have someone ready to catch it :lol:
It does not take huge amounts of pressure to shift the grip unless it was glued on. Obviously this wont work on clip-ons, or solid bars ;)
If you have conventional grips with the small holes in the end, you do not even need to remove the throttle sleeve. Just stick the duster gun in the throttle grip and it will shove the LH side grip off
1977 KZ650C1
1975 H1F 500 Triple
2005 ZX10R
Sheffield(ish) UK
Last edit: 27 Aug 2011 15:50 by Charlie650.
  • Topper
27 Aug 2011 16:06
#472170
Charlie650 wrote: It will blow your other grip straight off the bar so have someone ready to catch it :lol:
Really? That sounds kinda fun. I don't have an air compressor, but I've got a friend who would probably help with this.
Thanks for the tip!
1979 KZ750 Twin
  • Charlie650
28 Aug 2011 03:34 - 28 Aug 2011 03:35
#472282
It's likely not in the health and safety manuals - but i have removed lots of grips from customer bikes like that.
On normal handlebars - the only time it's not worked well, is when the grip has been glued in place. :)
1977 KZ650C1
1975 H1F 500 Triple
2005 ZX10R
Sheffield(ish) UK
Last edit: 28 Aug 2011 03:35 by Charlie650.
