'81 KZ1000 Cafe/Track Racer Questions
- Kwschin
26 Aug 2011 10:13
Have an '81 KZ1000 project bike, that I bought to do as a Cafe or Track racer. So far, other than riding a little and then stripping down, I've chopped the frame off, just past the shock mounts. Each time I look at the bike, I think "The Tank is Too Big." So, first question, anyone recommend a tank that will fit the triple tube frame?
Second item I would like to clean up is the upper triple clamp. I'm not going to run the "Steam Guages" so I'd like a cleaner triple clamp. Any suggestions on one that would work?
And lastly, the rear sprocket is from the days of 55mph maximum speeds, so it's gotta go. Need a source for sprockets and chain that will bring her up to par with the 70mph speed limits of today.
Thanks to all for any help.
Keith Schindler
South Central Texas
2009 Voyager
2003 Nomad
1980 KZ1000E
1978 Honda Hawk
1981 KZ1000 Project
Keith Schindler
South Central Texas
2009 Voyager
2003 Nomad
1980 KZ1000E
1978 Honda Hawk
1981 KZ1000 Project
- Marneman
Re: '81 KZ1000 Cafe/Track Racer Questions
29 Aug 2011 20:03
I ran into the same issue with my 82 KZ1000 LTD. I did quite a bit of research and there aren't many direct fit tanks. Our's are pretty much the same, as well as the cop bikes which fortuantely there are a million of. I think that possibly the squarish 1100 tanks of the same vintage might fit?? But I would do some research to make sure. I guess one could cut the tunnel off their exsisting tank, and then graft it into a smaller more aerodynamic one, but that far surpasses my fab skills.
Sorry no help on the triples.
Z1 enterprises has a good selection of chains and sprockets. Give em a call and tell em what you want to do with the sprockets, and they can help you sort it out.
Good luck!
Good luck!
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- Kwschin
29 Aug 2011 20:24
Hey, thanks for the bit of info. Hadn't thought about police bikes, wonder if the tank's a bit bigger. I'll check on Z1 and see what they got on the sprockets. Think I got an idea for the triples, involving a cafe or track fairing and a turned aluminum panel to clean up the area above the triples. Going to go with Clip Ons, so I'll use the bar mounts to mount the aluminum plate. Might run an electronic speedo there.
We'll see.
Shin
We'll see.
Shin
- wireman
29 Aug 2011 20:41
is an 81-82 gpz tank smaller?
