front end
  • customkz1000
  • customkz1000's Avatar Topic Author
front end
25 Aug 2011 21:49
#471778
When I go around a left hand corner at moderate speeds the front end wobbles. What could it be?
  • hocbj23
  • hocbj23's Avatar
Re: front end
25 Aug 2011 21:58
#471780
Possibilities:
Triple tree bearings worn and /or need adjustment.
Swingarm bushings worn
tire(s) worn or need balancing
front bearings worn and/or need repacking
the dreaded Kaw front end wobble-call for an exorcist.Lol.bj
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: front end
26 Aug 2011 10:15
#471912
bent rotor.
  • MFolks
  • MFolks's Avatar
Re: front end
26 Aug 2011 20:35
#472019
I copied this from a post from Jeff Saunders(owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace is worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
  • wireman
  • wireman's Avatar
Re: front end
26 Aug 2011 20:40
#472024
jack frontend of bike up off of ground and start shaking it side to side up/down B)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: front end
27 Aug 2011 04:45
#472099
wireman wrote: jack frontend of bike up off of ground and start shaking it side to side up/down B)
then do the rear end.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
