Fork seal replacement..Just a Humerous Post?
  • draboo
  • draboo's Avatar Topic Author
  • zzz
23 Aug 2011 12:38
#471163
I got a chuckle out of this..though it DOES sound feasible..:laugh:
advrider.com/forums/showthread.php?t=205643
1983 KZ1100D Spectre shaft
  • T_Dub
  • T_Dub's Avatar
Re: Fork seal replacement..Just a Humerous Post?
23 Aug 2011 13:06
#471167
I love that method!! Looks like it works great, dont even have to take out your fork tube!
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
23 Aug 2011 14:03
#471177
I'm cornfused (again). If the seal held pressure well enough to push itself out of the lower fork leg without leaking when using a jack to create very high pressure, it seems like it sure would not leak under normal use which generates much lower pressure. So why was he replacing it?? :unsure:
  • T_Dub
  • T_Dub's Avatar
23 Aug 2011 15:30
#471186
I'm sure it leaked, but if you do it fast enough I'm sure it creates enough pressure to force it out. After all, most fork seal leaks are very slow.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • wireman
  • wireman's Avatar
23 Aug 2011 19:36
#471224
thats a lot more work than just removing the allen head bolt from bottem with an impact! :woohoo:
  • draboo
  • zzz
23 Aug 2011 20:16
#471231
wireman wrote: thats a lot more work than just removing the allen head bolt from bottem with an impact! :woohoo:
'Tis true, but there are some of us (me,being one) who do not have an impact wrench,compressor,airline, and socket to do the job. I don't even have a garage. :(
I took some thin plastic and cleaned between the seal and the fork tube and am hoping I won't have to replace them. If they still leak, I will probably try this method. I do have a small jack and plenty of wood blocks. I m thinking of using ATF instead of oil.
If I do try it,I will post pics,maybe even a video.
Attachment 102_0208.JPG not found
  • martin_csr
  • martin_csr's Avatar
Re: -
24 Aug 2011 09:19 - 21 Feb 2013 17:54
#471413
Last edit: 21 Feb 2013 17:54 by martin_csr.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
24 Aug 2011 10:01
#471418
Jeez! It's a freakin' Ewok!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • draboo
  • zzz
24 Aug 2011 11:42
#471437
yea, that's our motorcycle-ridin' little freak, Kiddo! When she "sits pretty" she REALLY looks like one!
Here is one of her on the back of our Spyder.."WHATS THE HOLDUP??"
Thought I d spice up this thread a bit..:)
Attachment pookie2.JPG not found
  • wireman
  • wireman's Avatar
24 Aug 2011 15:50
#471479
now thats freaking cool,more than makes up for not having a garage! :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
  • draboo
  • zzz
19 Sep 2011 12:28
#477870
Well..I must report back about my front fork seals! I did clean em out with some pieces of thin plastic, like using THIS .
I first drained the forks for a few days to get the dirty oil out and refilled with some fresh.
It worked like a charm. The leakage has stopped. I used some plastic from a orange juiced jug and cut it to roughly the shape of a sealmate. I did the procedure 3 times on each side. The seals themselves looked in great condition.
So, at the cost of $0.00 and around a half hour labor(15 to 20 minutes digging thru the recycle bin for proper thickness of plastic and cutting to shape, and 10 minutes of actual cleaning), I d give this procedure a "WTH,it can't hurt"! before tearing into a total fork seal replacement.
